anyone experience rattling???
Old Aug 20, 2003 | 03:09 PM
exr_pd's Avatar
Default anyone experience rattling???
i just installed a set of adj. coilovers with new strut bushings and there seems to be a rattling noise coming from my rear suspension and trunk when i hit a bump. is there anything to blame for this? and can i fix this? or is it just something i have to deal with?
Old Aug 20, 2003 | 04:37 PM
CaptainObvious's Avatar
Default Re: anyone experience rattling??? (exr_pd)
Did you bolt everything back up? I had a noise in my front end then i realized the sway bar wasn't bolted on 1 side
Old Aug 20, 2003 | 04:47 PM
p0pe's Avatar
I have a similar problem, I believe its due to either the progressive coils of my springs hitting against each other, or possibly that I didn't cut my bumpstops and my shocks are bottoming out prematurely... I haven't been able to figure it out, but it seems to be a common problem from what I've read. Tightening up my shocks did help some, so try that and see.
Old Aug 21, 2003 | 12:51 AM
blurr's Avatar
Default Re: anyone experience rattling??? (CaptainObvious)
it's usually from the sway bars.. either it's not bolted on well, or it could be that the end link bushing is worn out..
Old Aug 21, 2003 | 06:36 AM
accordboi's Avatar
Default Re: anyone experience rattling??? (blurr)
No rattle here...just a clunk sound in the rear passenger wheel when i go through a speedbump. This is with my eibach springs. Supposedly, its just dead coil area hitting each other.
Old Aug 21, 2003 | 09:29 AM
exr_pd's Avatar
i noticed someone mention bumpstops, where is that located? cuz when i lowered my car, i did have my shocks bottoming out, so i had to raise it back up a bit to give the shocks more room to move! maybe this is my problem?!
Old Aug 22, 2003 | 05:13 AM
p0pe's Avatar
they're located on the strut rod
the #s represent where the bumpstop would be on a strut, its basically a rubber/polyer (i think) type cushion.
BKJJ77
23
Mar 23, 2012 05:52 PM
rathead81
Sep 22, 2006 03:27 PM
the soL that could
Suspension & Brakes
Aug 7, 2006 01:25 PM
mdixonjam
Suspension & Brakes
Apr 18, 2005 05:52 PM
