JRSC type R at 9psi....= 13.703@108.56 on winter tires!
13.703@108.56
Well im not really happy but I guess its what I expected with winter tires!
I got 247WHP and 170WTQ....
my 60 foot was 2.31.....
JRSC @ 9.5 PSI, hondata Tunned
I guess I need slick pretty badly!
Tyler
Tyler
The trap speed is good. What are you expecting with only ~250whp? You should run 13.2-13.3 easy on slicks.
Real good, I ran 14.0 @103.5 like 4 times in a row on Kumho's 712's here in Carlsbad raceway... slipping in 1st and 2nd all the way down the track... at 6psi stock boost for me..... Hondata tuned also....
Yea sounds like you are spinning pretty bad i ran a 13.8 in a civic si on 10psi at like 112 mph so i know where you are comming from on the spinning aspect of things. good 60ft time though. if you can knock it down two more 10ths that would put you at a good time. with traction bars and slicks you should be able to pull that one off easy.
