What kind of teflon paste do i use on oil fittings? permatex brand ok?
Old Aug 20, 2003 | 02:41 PM
2000vsm's Avatar
Default What kind of teflon paste do i use on oil fittings? permatex brand ok?
Ok i bought some permetex brand for sealing threads at high temp/pressure.. i'll have a pic within 45 min of the stuff...
if not that, what is the best thing for sealing those npt/bspt threads.. don't worry.. no **** on AN fittings
Old Aug 20, 2003 | 03:33 PM
shortyz's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (2000vsm)
use teflon tape.. works for me.
Old Aug 20, 2003 | 04:00 PM
boostaholic's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (shortyz)
I like to use the Teflon paste rather than the tape. The tape peels off too easily sometimes when you start threading it in.
Old Aug 20, 2003 | 07:31 PM
2000vsm's Avatar
here it is.. should i use this or where can i get what people are using?
Old Aug 20, 2003 | 09:13 PM
MADEINIRAQ's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic &raquo;</TD></TR><TR><TD CLASS="quote">I like to use the Teflon paste rather than the tape. The tape peels off too easily sometimes when you start threading it in.</TD></TR></TABLE>
if the tape peels off... are you sure you put it on in the correct direction?
teflon tape should be sufficient..
Old Aug 20, 2003 | 11:28 PM
psileepR's Avatar
New User
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (madeiniraq)
just go to any home depot, lowes etc... you can buy a larger tube of teflon paste for half the price.. trust me. the stuff they sell at automotive stores is a bit overpriced.
ps. to answer your question... that will work just fine. if u want to save money check out the other stores i mentioned above.
Old Aug 21, 2003 | 04:51 AM
turbotypeR@SPEC's Avatar
25 Year Member
hondabond
Old Aug 21, 2003 | 05:55 AM
int3gra's Avatar
canadian tire
Old Aug 22, 2003 | 06:36 PM
2000vsm's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (int3gra)
what is it called.. ??!?
like "TEFLON PASTE"
isn't some for only like hot/cold water at reg temps? our engines create like 50psi of HOT oil, like 100+ celcius...
Old Aug 22, 2003 | 07:25 PM
BodyKits NW's Avatar
So what is silicone mostly used for. Cause I bought silicone to use on the threads.
Old Aug 22, 2003 | 07:37 PM
W.Zero's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">hondabond </TD></TR></TABLE>second this
Old Aug 25, 2003 | 03:43 PM
shortyz's Avatar
Default Re: What kind of teflon paste do i use on oil fittings? permatex brand ok? (W.ZeroB18C1T)
tape only comes off when u wrap it the wrong way. or u wrap way to much.
not to mention doesnt needa dry.
Old Aug 25, 2003 | 05:37 PM
GSRswapandslow
Guest
Posts: n/a
teflon gooooo ownz j00
but teflon tape works great too
i've never tried hondabond...you guys being serious?
Old Aug 25, 2003 | 05:54 PM
rOby's Avatar
Default Re: (GSRswapandslow)
teflon paste, the tape can come apart and loge in ur line. not good. use the paste, get it at home depot or loews
Old Aug 25, 2003 | 06:05 PM
V-SPEC 1's Avatar
Default Re: (rOby)
Yeah, You never want to use the tape because it can clogged up. I use the one from home depot called: thread sealant with teflon. Make sure it says teflon on it. Teflon protect your thread. Or use Permatex thread sealant with teflon.
Vic
Old Aug 25, 2003 | 06:44 PM
2000vsm's Avatar
Default Re: (boostedb20vtec)
got it.. it's white tube with black writing on it... like $2.00
get it... it's good ****.. we will see how good **** it will be tomorrow
krysted9354
Nov 5, 2008 09:33 AM
Bulli Kid
41
Aug 24, 2007 06:36 PM
string
Oct 3, 2006 09:12 PM
builtboostedteg
Sep 21, 2006 04:18 PM
ck123
10
Jan 20, 2006 08:55 PM
