Where can I get a 2.5 Test Pipe for an OBDII Integra?
I need a stainless Steel TEst PIPE with no resonator for an OBD II Integra, that will nOT cause my ECU to pop a CEL. I remember there was something on GROUPBUYCENTER but It's no longer there.
if i recall..the only reason the ECU gets a code is because of the missing o2 sensor. Just install another o2 sensor in the test pipe, and you should be fine. I bet a muffler shop could make one for $30.
liam
liam
no core material and your going to pop a light... that's the cool thing about Dan's pipes is that it has some core in it to keep the O2 happy...
Dan, aka God at http://godspeed.hack.net...
FYI: My OBDII 96 GSR doesn't throw codes with my straight pipe. Both O2 sensors are mounted in the pipe and reporting to the ECU. No cat material anywhere.
It might work for your 96 too.
Greg
Greg
