car idles low when the A/C is on...wtf.
Old Aug 20, 2003 | 01:57 PM
ILOVEGIRLS's Avatar
Default car idles low when the A/C is on...wtf.
what causes this to happen? i want to fix this..it will idle low then drop causing the car to shake and bounce up about 500 rpm. lmk. thanks
Old Aug 20, 2003 | 02:24 PM
King_j's Avatar
Default Re: car idles low when the A/C is on...wtf. (ILOVEGIRLS)
what does it idle at normally ( as in when the a/c is off) ? you will notice a drop in rpms when the a/c is on due to the amount of power it needs.
Old Aug 20, 2003 | 02:33 PM
NeoGSR's Avatar
Default Re: car idles low when the A/C is on...wtf. (King_j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j &raquo;</TD></TR><TR><TD CLASS="quote">what does it idle at normally ( as in when the a/c is off) ? you will notice a drop in rpms when the a/c is on due to the amount of power it needs.</TD></TR></TABLE>
it shouldn't be that low though.......the ecu should compensate for the power that the AC takes......
Old Aug 20, 2003 | 02:43 PM
ILOVEGIRLS's Avatar
It idles normal but when the A/C is on it idles lower causing rough idle.
Old Aug 20, 2003 | 03:31 PM
teg92's Avatar
there could be something wrong with your IACV
Old Aug 20, 2003 | 03:45 PM
ILOVEGIRLS's Avatar
Default Re: car idles low when the A/C is on...wtf. (teg92)
what does the IAVC do?
Old Aug 20, 2003 | 03:56 PM
darkirony's Avatar
umm my rpms jump up bout 50 when i turn ac on..
Old Aug 20, 2003 | 03:58 PM
RedLinin247
Guest
Posts: n/a
Default Re: car idles low when the A/C is on...wtf. (darkirony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkirony &raquo;</TD></TR><TR><TD CLASS="quote">umm my rpms jump up bout 50 when i turn ac on..</TD></TR></TABLE>
does this make no sense? or is it me?
Old Aug 20, 2003 | 06:35 PM
TEXN3's Avatar
Default Re: car idles low when the A/C is on...wtf. (RedLinin247)
it does that in my car when the car is in park. the rpm's rise a little and fall. its very normal in 4cyl cars that don't have alot of lowend power. its another reason i seldom use mine when sitting in traffic, well that and the weather isn't too bad in utah. plus, you don't get good airflow thru the radiator when sitting idle.
94c1v1cex
Jul 20, 2007 11:15 AM
93JDMB18C
Nov 2, 2006 02:03 PM
Freshsho
May 25, 2005 12:49 PM
iCe_2x
Dec 23, 2004 08:58 PM
hatchfreak92
Oct 17, 2004 08:59 PM
