Water pump???
Old Aug 20, 2003 | 01:31 PM
RussHondaCRXVtec's Avatar
Default Water pump???
I'm getting my motor swap done in a couple of days and the guy who is doing it said i would need a new water pump and timing belt i can understand timing belt but do i really need a new water pump??? just give me yes or no or some of your thoughts on this thanx!
Old Aug 20, 2003 | 01:44 PM
Fardoche's Avatar
Default Re: Water pump??? (Russ1414B16a1seeya)
Its best to replace the water pump for the reason that if it seizes chances are it will snap the timing belt. I wish I had known before doing my swap
Old Aug 20, 2003 | 01:54 PM
RCautoworks's Avatar
Default Re: Water pump??? (Fardoche)
Yes do it now while the engine is out, you will save money and not have to worry about it not working or leaking.
Old Aug 20, 2003 | 02:00 PM
bossman032's Avatar
Default Re: Water pump??? (90blackcrx)
I say don't **** with it.
u want the motor as is start it up first then do its much easyier when u know ur motor is running
my 2cents or at least open the cover inspect the BELT!!
Old Aug 20, 2003 | 02:01 PM
RexB16's Avatar
ya, its like 30 bucks... replace it.
Old Aug 20, 2003 | 02:27 PM
EL Vap133's Avatar
Yes do it now, if not you will get charged twice the labor to do it when it goes out and the motor is in.
Old Aug 20, 2003 | 02:32 PM
Creepshow S60's Avatar
Default Re: Water pump??? (Vap133)
yes, replace it. save you time and money by doing it now.
Old Aug 20, 2003 | 02:42 PM
Crxer's Avatar
Default Re: Water pump??? (y-49CRX)
yeah i would do it now, its a pain in the *** to do later on if not.
spluvs2install
Aug 26, 2006 07:40 PM
efyou
Jun 21, 2006 12:30 PM
1998hondaaccord
Sep 18, 2003 05:00 PM
