exhaust paint!
Old Aug 20, 2003 | 09:14 AM
hks3630's Avatar
Default exhaust paint!
i just receved my brand new hks hi power cat back exhaust system and a small spot has been worn to the bear metal. i try to fix that by simply covering it w some high temp paint. i had a little over spray so i wipe it off and it took off the factory paint with it!!! so i take it all off and now have to fix a big spot.why did it do that!?what kind of paint can i use? plz hurry.....gotta get thta exhaust on quick!
Old Aug 20, 2003 | 01:05 PM
axhandler's Avatar
Default Re: exhaust paint! (hks3630)
Brand new exhaust had spot worn to bare metal....hummm....I would have sent it back. Why are you worried about it anyway? Can you see it when it's mounted on the car? If anything just spray it with the high temp paint and be done with it.
Good luck.
Old Aug 22, 2003 | 07:29 PM
LANDYcolorLAB's Avatar
Well actually you have about 4 options here. First being the best, if you got the money take it in ang get it powder-coated. It will make it look custom and keep it from being to badly worn. Second you could get some POR-15 manifold paint and brush it on, it lays out smooth by its self. Comes Black ,Silver or aluminum. Third you could just keep using the high-temp stuff in spray cans and keep doing that ever so often to maintain it. Fourth return it, but whay thats time wasted and like the manufacture cares about the finish.
Mikey
Old Aug 24, 2003 | 10:40 PM
playAho's Avatar
Default Re: (LANDYcolorLAB)
bump for some good paint info!!
CooBlueDAB
Sep 27, 2005 07:22 PM
gapsook
Jun 19, 2004 09:35 AM
es_squared
Jun 16, 2004 09:27 PM
nick2kcivic
Oct 1, 2003 11:23 AM
B18Redline
Jun 21, 2003 09:58 AM
