Vafc question- Vti, VTo?
Old Aug 20, 2003 | 09:09 AM
genetsang's Avatar
Default Vafc question- Vti, VTo?
i was simply browsing through my Vafc's features.. and i stumbled across the VTi and Vto option..... This was in the MONITOR setting and it says it both VTi and Vto was OFF.. i just wanted to know whether the VTi and Vto is suposed to be on or off... thanks
Old Aug 20, 2003 | 09:41 AM
JDM_Risa's Avatar
Default Re: Vafc question- Vti, VTo? (genetsang)
vto only turns on when u engage into vtec...........right at the switchover it shud display ON try it for yourself i dunno about VTi
Old Aug 20, 2003 | 09:44 AM
genetsang's Avatar
Default Re: Vafc question- Vti, VTo? (GunMETAL_TEgRa)
thanks... im trying to find out about VTi
Old Aug 20, 2003 | 10:35 AM
92lsr's Avatar
vti is where u can adjust the vtec
example
lo-hi 5700
hi-lo 5600
from what i was told please tell me if i am wrong , the low vtec cam opens under a certain rpm for example 5600 , the lo-hi xover is when the high profile vtec cam kicks in for example 5700
you can move the vtec up and down , i believe stock is around 4400 on a stock gsr ecu ,but the best way to adjust it is tune it on a dyno
Old Aug 20, 2003 | 10:55 AM
genetsang's Avatar
Default Re: Vafc question- Vti, VTo? (92lsr)
dunno. trying to figure it out myself.. but what im trying to find out is.... On stock settings.... would the VTi be "ON" or "OFF"? currently when the car is idleing the VTi says its "OFF". The reason why im asking this is b/c i was afraid that i might of accidently pressed something that i wasnt suposed to.. and that was the reason why the VTi and VTo is "OFF" position.
So far what i understand is. VTo will only say "ON" when vtec is engaged...
so now what im trying to find out is... is that the same with the VTi?...
Old Aug 20, 2003 | 11:06 AM
92lsr's Avatar
looks like you got the vto and vti on the monitor , here is a quick test take your car to up to 6,000 rpms vtec should engage and both should say on , vti turns on when vtec engages , i havent messed with my vto
Old Aug 20, 2003 | 11:08 AM
.xcalibur.'s Avatar
VTi is when the ecu tells the VAFC to engage vtec.
VTo is when the VAFC tells the car to engage vtec.
Both should be off until you punch it. -=o)
Old Aug 20, 2003 | 11:12 AM
Tweakmeister's Avatar
Default Re: Vafc question- Vti, VTo? (.xcalibur.)
set them to 4300/4200 or something around there.
on the dyno you'll see where your power curve dips and you can adjust vtec accordingly.
easy as cake, and fat free too!
Old Aug 20, 2003 | 11:53 AM
genetsang's Avatar
Default Re: Vafc question- Vti, VTo? (Tweakmeister)
thanks alot guys. i got it tuned a while back.. just stumbled across it and noticed that it was off... but just like how you ppl said... it would come "ON" when vtec is engaged... THanks thats all i need.
DC2teggY
Apr 6, 2009 02:37 PM
shadow103rd
23
May 13, 2004 04:50 PM
2lobes1engine
15
Apr 12, 2004 10:33 AM
genetsang
Aug 20, 2003 01:54 PM
EGtoR
Jan 19, 2002 11:27 PM
