WHP preditions for this NA setup. Need some help and insight
Old Aug 20, 2003 | 08:55 AM
mamaboy's Avatar
Default WHP preditions for this NA setup. Need some help and insight
The setup below is entirely geared toward autox / road race...once i go to driving school. for the peeps who are familiar with rules and regulations at these events...how will this setup effect my status at an event? I just need to adjust and add/remove some stuff, through some of your suggestions. I'm thinking i can push 190WHP with this setup, which is exactly all i want. please suggestions and insight. and this is for a B18C1...I'm ready to start buying parts....just need some final decision tweakings
- Toda Spec A Cams
- Toda Cam Pulleys
- Toda Timng Belt
- Toda Oil Pump Gear
- Toda Valvetrain
- Mugen Baffled Oil Pan
- Mugen Head Gasket
- Hytech Spec 1 Exhaust Manifold + Complete Exhaust System
- Comptech Ice Box
- Mocal Oil Cooler
- Mocal Thermostat
- -10an HP Lines + Fittings
- Hondata S100 ~or~ S200
- RC Injectors 310cc ~or~ Stock?
- B&M FPR...i'm sure this FPR will do fine
Old Aug 20, 2003 | 09:02 AM
lustedp's Avatar
are you going to include any headwork, p&p, valve job
Old Aug 20, 2003 | 09:08 AM
GokuSSJ4's Avatar
Default Re: (lustedp)
also stock bottom end or are you planning on running higher CR ???
Old Aug 20, 2003 | 09:15 AM
mamaboy's Avatar
Default Re: (Spoon1)
stock everything. compression bump .04 with the head gasket....so i'd be @ 10.4:1...hence i'm not exactly too keen on buying the Spec B's...i won't use them to the fullest capacity. daily driven as well. pump gas....Cali 91shitane. In addition, I don't want to upgrade the throttle body or intake manifold. I just want to massage it alittle bit, but without a drastic change. Transmission is what i need to work on next, but probably keep the stock gearing and just add an LSD
Old Aug 20, 2003 | 11:00 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: WHP preditions for this NA setup. Need some help and insight (mamaboy)
From what I've seen you should be able to hit 190whp pretty easy with good tuning.
Old Aug 20, 2003 | 11:10 AM
H-PIMP's Avatar
Default Re: WHP preditions for this NA setup. Need some help and insight (ActiveAero)
190+ is realistic.
Old Aug 20, 2003 | 11:14 AM
mamaboy's Avatar
so my setup is solid in your opinion...correct? for 190WHP? Sorry for the newbie question, but I was immersed in FI train of thought for the longest time, until autox / road race started to really catch my attention. thanks again
Old Aug 20, 2003 | 02:30 PM
snake01's Avatar
I made with the same exact setup 180/125 on a mustang dyno
TheShodan
Jul 6, 2005 04:01 PM
JDMsurf
Oct 5, 2004 02:18 PM
mamaboy
Aug 17, 2003 08:53 PM
Montreal R
Oct 29, 2002 08:21 PM
