Can a ls Computer be chipped out to vtec specs....
Old Aug 13, 2001 | 06:30 PM
powerfulperformance's Avatar
Default Can a ls Computer be chipped out to vtec specs....
I have an ls computer, and i wanted to find out if i can get it chipped to vtec...and if it can be used with the gsr..
Old Aug 13, 2001 | 07:38 PM
HXMan's Avatar
Default Re: Can a ls Computer be chipped out to vtec specs.... (powerfulperformance)
If the ECU you are using doesn't have a function stock, it cannot be made to work with that function later.
So no.
Old Aug 13, 2001 | 08:25 PM
Dr Pooface's Avatar
Default Re: Can a ls Computer be chipped out to vtec specs.... (HXMan)
In the sept issue of Sport Compact Car, in their article "Hybrid How-To", They
are putting a prelude engine in a civic. On page 192: "The Civic didn't come with
VTEC, but its ECU is pre-configured to accept inputs from an engine with this
feature."
Maybe all Honda ECU's are like this??
[Modified by Dr Pooface, 5:26 AM 8/14/2001]
Old Aug 13, 2001 | 10:13 PM
sgT's Avatar
sgT
Default Re: Can a ls Computer be chipped out to vtec specs.... (Dr Pooface)
Yes you can convert the LS ECU to run a vtec engine.
SCC is full of useless ****. They meant wiring harness, and even then only SOME
civics were prewired for vtec.
Old Aug 14, 2001 | 05:29 AM
4doorRS5spd's Avatar
New User
Default Re: Can a ls Computer be chipped out to vtec specs.... (sgT)
Try http://www.jdmhondaparts.com and look under the ECU upgrades section. Also, try http://www.hondata.com
Old Aug 14, 2001 | 02:40 PM
Hondata's Avatar
We have converted an LS P74/P75 ecu, when running with a Hondata stage 2 upgrade and GSR maps to drive a GSR with secondary intake runners. We have not yet made this upgrade available for sale.
Because the P74/P75 does not have a knock sensor, a Hondata upgrade must be used so as not to cause a knock sensor error.
If you do not use the secondary intake runnner switching, a Hondata system and modified P28 will work OK.
Doug
94-integra-ls
Mar 23, 2008 04:26 PM
sixtodc4
Jan 11, 2008 02:36 PM
Dc2 Joe
May 23, 2007 04:35 PM
Dc2 Joe
May 23, 2007 01:03 PM
bboysake
Jun 20, 2006 11:36 PM
