pr3 chips
ok i need another ecu for starters, 2 the 112 mph thing sucks ***, my g/f's v6 stang beats me in top end
wich really sucks. how much am i looking at and where do i get a qaulity chip and keep my knock sensor
From what I understand a PR3 cannot be chipped, You'll need the P28. I would highly reccomend keeping the PR3 alone and adding a Feilds Boxer. It will let you adjust fuel, vtec crossover and remove the speed limiter. With the S1 tranny my b16 propells my 90 crx to 148 mph @ 8400 rpm in 5th gear (tested and true)
Brian
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BdoubleU »</TD></TR><TR><TD CLASS="quote">From what I understand a PR3 cannot be chipped, You'll need the P28.</TD></TR></TABLE>
Are you kidding me? The PR3 is probably the most chipped ECU out there... try http://www.hyperducktuning.com
Oh by the way, the knock sensor goes into open loop (becomes useless) when you're above 5000 rpm or so.
stronger top end then the factory pr3. no rev limiter is scary as ****!!!!
