ZC Tranny Hops back and forth HELP!!
Old Aug 19, 2003 | 11:33 PM
Eskay@JDMCircle.com's Avatar
Default ZC Tranny Hops back and forth HELP!!
Hey guys, When i drove the crx today, everytime i shifted and let go of the gas or clutch the shifter would jump a lil up and down or back and forth in a stiff motion? I'm not sure if i can explain this correctly but pretty much the shifter is hopping back and forth about half an inch when I execute the complete shift into a new gear.
Also how can i tell if my tranny is a ZC tranny? PLEASE HELP!!
Old Aug 20, 2003 | 04:28 AM
keithv's Avatar
Default Re: ZC Tranny Hops back and forth HELP!! (skt)
if i follow what your are saying, it sounds like one or more of your tranny mounts are broken/worn.
as for IDing your tranny, i know there is a post about IDing the Si tranny, but i don't think i have seen on for a ZC tranny...
Old Aug 20, 2003 | 11:53 AM
nuc79's Avatar
Default Re: ZC Tranny Hops back and forth HELP!! (keithv)
Take the tranny apart and count the teeth on the gears. The Final Drive on a jdm ZC tranny is 3.88 : 1(same as DX). But gears 1-5 are shorter. Basically, count the teeth on the 6 pairs of gears that mesh together and divide the two numbers(bigger divided by smaller, except for 5th). Results should be: http://www.hondaswap.com/refer...id=65 I know it sounds like a pain, but my tranny was hand-marked "SOHC ZC", and by using this method, I was able to tell it's really an Si tranny because of the 4.25 final drive (68/16 teeth=4.25).
Oh, and I second the motion for broken tranny mounts. Check the front one first.
Old Aug 20, 2003 | 12:22 PM
pony2slow's Avatar
mine does the samething.. was told the mounts were bad.
Riceboy891
Jul 18, 2008 04:32 AM
89efhatchcrap
May 4, 2006 06:43 AM
sloweredcivic
Oct 16, 2003 03:27 AM
91hatchnewb
18
May 12, 2003 08:49 PM
