homemade camber kit?
Old Aug 19, 2003 | 10:22 PM
weakGOODJunKieS.com's Avatar
Default homemade camber kit?
i read somehwere that u can adjust the camber on your car with some washers and bolts. can anyone give me link on a _how to_ of some sort? i have hr sports and the camber in the front is off and the rear is off by a little as well (not as much as the front) thanks
Old Aug 19, 2003 | 10:43 PM
CircuitFG's Avatar
Default Camber Washer Trick
TAKEN FROM G2IC.COM
For a DA integra, but should be generally the same. .
Correcting Camber in Rear Wheels.
If you want to get rid of negative camber because it's eating your tires you can do this:
1- Jack up your Integra and remove the wheel.
2- There's an arm that attaches to the car right besides the gas tank when you look straight through the wheel well and it has two bolts attaching it to the car.
3- Remove these two bolts and insert metal washers between the arm and the car and reinstall again.
4- Number of washers or thickness depends on how low your car is dropped. Mine is dropped 2" in the back and I used (2) 1/16 washers at each bolt i.e. (4) washers for each wheel. If your car is dropped more you'll need more washers but have to get a longer bolt too. Good luck.
5- Camber correction for the fronts however requires purchasing a camber kit OR some really heavy duty modifications to the front fender OR bending the "spindles." (the last two are not good and not recommended)
Modified by CircuitDA9 at 11:12 AM 8/20/2003
Old Aug 19, 2003 | 10:45 PM
xx dc2teg xx's Avatar
yes i have washers in the rear for my car, works pretty good
team-integra has an article
Old Aug 19, 2003 | 11:02 PM
Default Re: (xx dc2teg xx)
how much am i looking at for a front camber kit?
Old Aug 19, 2003 | 11:05 PM
cccccccc's Avatar
Default Re: (FrostWhiteDC4)
ya washers will work good
and get the skunk 2 front camber kit, it cost $190
but i've seen the others and they aren't nearly as good as that style kit
JustOneOrTwoPosts
Honda Civic (2006 - 2015)
Jul 15, 2012 09:42 AM
Lipan90crx
10
Aug 7, 2008 10:50 AM
jnuanz382
Dec 10, 2006 07:57 PM
EK k kay
Suspension & Brakes
Aug 30, 2005 10:57 AM
jonsteR
Sep 7, 2001 07:54 AM
