How do you hook up a coolant temp gauge??? need help
ok the gauge in my cluster is fucked due to what seems to be electrical problems in the harness...so what is there out there i can rig up to tell how hot my engine is running and how hot my coolant temps are.....any help is appreciated...tia
Modified by Eyewitness at 8:52 PM 8/19/2003
if you follow the radiator hose, you should see a metal piece that sticks out, and it's about half an inch. use a flash light if you can't see it. the best advice would be to look under helms manual bc that's where i found it to be most helpful. good luck on the wiring. i had the same problem
