Temp Sending Unit
Old Aug 19, 2003 | 05:40 PM
1slowaccord's Avatar
Default Temp Sending Unit
I just bought a new sending unit for my 95 accord LX. Can anybody help with instructions on how to put it in. If you have any links for picts. that would help a lot.
Old Aug 19, 2003 | 05:47 PM
DrunkNRacer's Avatar
Default Re: Temp Sending Unit (Spliff101)
Is it stock sending unit.. or is it aftermarket?
If its stock.. than just replace it.. (its right next to the oil filter)... youll need a deep socket wrench (i think its 22,23, or 24mm)..
Modified by G-villeRacer at 10:24 PM 8/19/2003
Old Aug 20, 2003 | 05:10 AM
JimBlake's Avatar
Default Re: Temp Sending Unit (G-villeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">... (its right next to the oil filter)...</TD></TR></TABLE>You sure? I don't have a '95, but I thought the one next to the oil filter was the pressure switch for the oil idiot light...
On my '98 (also my '95 Teg) it's up near the upper radiator hose.
Old Aug 20, 2003 | 05:34 AM
GimpyAccord's Avatar
Default Re: Temp Sending Unit (JimBlake)
The accord has 1 2 3.. count them *4* temp sending units of various use *yikes*.
One on the back of the head in the thermostat housing. (ECU use)
One in front of the head on the water outlet. (ECU use)
Two right smack in the middle of the head for the temp guage and the fan. If you're replaceing the one for the temp guage, look for the one with a large single black slip on connection. All the others use a GREEN connectors.
The sensor on the back of the block by the oilfilter is the oil pressure sender
Old Aug 20, 2003 | 05:56 AM
jweller's Avatar
Default Re: Temp Sending Unit (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">One in front of the head on the water outlet. (ECU use)</TD></TR></TABLE>
thats interesting because the F23 doesn't have one there, but the water outlet neck has a spot in it that looks like it should have one. It's exactly where I put the sensor that came with my autometer water temp gauge. I guess thats a good spot to put it
I'm pretty sure the one on the thermostat housing is only used to turn the radiator fan on/off.
Old Aug 20, 2003 | 06:53 AM
Default Re: Temp Sending Unit (jweller)
According to my 1991 electrical trouble shooting manual, the thrmo housing and water outlet (obviously they quit doing the outlet housing on 98+ or something) is for ECU use. It goes on to show that the larger water temp sensor on the middle of the head is used for fan.
Obviously this coulda changed over the years. My 1991 harness did have all of those sensors available to me though. I'm not certain of the year my head is from and it came with the water outlet attached.
thermo housing:
the rest. sorry 2 pics, but i didnt have the housing on yet in this picture:
Old Aug 20, 2003 | 08:07 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">... Obviously this coulda changed over the years...</TD></TR></TABLE>Yikes. They did change them.
rode2nowhere
Jan 8, 2019 11:10 AM
Kenneth723
May 17, 2017 01:05 PM
mani_0130
Mar 1, 2009 08:36 AM
citizen21
May 11, 2008 07:51 PM
01YellowITR
Feb 5, 2002 10:21 PM
