Squeaking noise when making right turns!
Old Aug 19, 2003 | 03:38 PM
Accorddude's Avatar
Default Squeaking noise when making right turns!
I have a 92 accord ex-r and it makes this annoying squeaking noise when i make right turns. It doesn't do it all the time. I think its coming from the front right. Any suggestions would be great!
Old Aug 19, 2003 | 03:53 PM
FatJoe's Avatar
Default Re: Squeaking noise when making right turns! (Accorddude)
check ur suspension components for anything outta the usual. you might not be able to spot it unless u have a clue what ur looking at but it could be anything considering ur suspension on sure.
Old Aug 19, 2003 | 04:43 PM
Mike813's Avatar
well i had the same problem a couple months ago, and it was because of my brakes, bring it into any place that does free check ups and get it pinpointed. anything squeaking cant be good.
Old Aug 19, 2003 | 05:30 PM
DrunkNRacer's Avatar
Default Re: Squeaking noise when making right turns! (Mike813)
It could be Brake Indicators... If not your brakes..
Get some silicone spray or wd40 and give your bushings a dousing and see if it goes away. trailing arms, upper/lower control arms...
Do you have any aftermarket suspension parts??
Old Aug 19, 2003 | 05:32 PM
AngryTroll's Avatar
Default Re: Squeaking noise when making right turns! (G-villeRacer)
Brakes....pretty soon it will do it all the time. straight or turning...
And then...it will quit...
And then....grind..growl...grind...
Old Aug 19, 2003 | 07:25 PM
Accorddude's Avatar
Well I don't have any aftermarket suspension parts but I'm planning on putting some coilovers. But I'll take everyones ideas into consideration. Thanks again!
tpot90
Oct 18, 2010 09:28 PM
thtguybryan
Mar 7, 2008 03:26 AM
MulletManRockStar
Mar 6, 2005 10:26 AM
94maroonturbocp
Oct 23, 2003 03:18 PM
BrandonClaps
Jun 28, 2003 02:57 PM
