Do all B-series use the same oil filter?
Is the same oil filter used throught the entire B-series line-up. More specifically I'm looking at purchasing some oem filters in bulk on ebay and want to make sure that I don't end up with a bunch of filters I can't use!! I have a 97 JDM ITR B18C. Anyone have the correct part numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolimits »</TD></TR><TR><TD CLASS="quote">Is the same oil filter used throught the entire B-series line-up. More specifically I'm looking at purchasing some oem filters in bulk on ebay and want to make sure that I don't end up with a bunch of filters I can't use!! I have a 97 JDM ITR B18C. Anyone have the correct part numbers?</TD></TR></TABLE>
Yes, even H and F series use the same.
Yes they do Matt
well not ALL their engines... i believe...90's and up they were mostly the same, except for some of the motors in the acura, and of coarse the new K-series is not the same.
but as for b-series yes they are all the same.
You are correct .. all 90-00 4 cyl honda use the same oil filter. the new K series has a smaller filter. i was wondering if that created more oil presurre. I will research and let you guys know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com »</TD></TR><TR><TD CLASS="quote"> the new K series has a smaller filter. i was wondering if that created more oil presurre. I will research and let you guys know.</TD></TR></TABLE>
I've heard numerous rumors about that as well, but nothing solid. Maybe I haven't researched enough
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">thought the k series were bigger ? (filters)
</TD></TR></TABLE>The new filters are smaller in diameter, about the same length. Same base, thread, & gasket. The new filters fit on the old engines, but the bigger old filters don't fit on the K engines. There's something in the way...
There's a couple orphans with different filters, like the Passport. Which is really an Isuzu anyway...
</TD></TR></TABLE>The new filters are smaller in diameter, about the same length. Same base, thread, & gasket. The new filters fit on the old engines, but the bigger old filters don't fit on the K engines. There's something in the way...There's a couple orphans with different filters, like the Passport. Which is really an Isuzu anyway...
Insights use very tiny Toyo Roki filters that have the same inlet and gasket diameter as a B-series. Might be a good choice for an engine break in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioXtremes »</TD></TR><TR><TD CLASS="quote">are d series the same as well?</TD></TR></TABLE>
Read the whole post
Read the whole post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com »</TD></TR><TR><TD CLASS="quote"> i was wondering if that created more oil presurre. I will research and let you guys know.</TD></TR></TABLE>
yes , it does.
rumored at 20psi more under WOT.
why you think you need more oil pressure is beyond me though
yes , it does.
philosofy1
12
Sep 29, 2005 06:24 AM
pezzy
Jun 27, 2004 03:40 PM
