way to plug cat o2 sensor please read!!!!!!!!!!
Old Aug 19, 2003 | 11:58 AM
tegrunner's Avatar
Default way to plug cat o2 sensor please read!!!!!!!!!!
i have a 00 integra ls
i have a carsound cat custom welded for my car and it has a hole for the o2 sensor
this hole is located in a poor spot .
when the cat is bolted on the o2 sensor falls inbetween the shift bar under the car and the shift stabilizer bar. if i get smaller bolts and twist the cat in place 1/8th of an inch up the o2 sensor does not rub against my shifter. what should i do
has anyone else had this problem
if i twist the cat when i bolt it down it leaks.
should i twist the cat so that the 02 sensor points to the other side. and but connect its connectors
or should i just plug the hole with a bolt and snip the o2 sensor.
also my engine light is on because of the high flow cat. and i think 4-1 dc header
what should i do is there a way to get my check engine light to go off so the car can read the right oxygen amounts.
thanks for your help in any way
Old Aug 19, 2003 | 02:04 PM
svtec's Avatar
L D E S
Default Re: way to plug cat o2 sensor please read!!!!!!!!!! (tegrunner)
i usually take care of that before i bolt the cat back in.
it's a helluva lot easier that way.
sorry.
JDM-Vic
Apr 29, 2010 05:04 PM
kaka10
Nov 29, 2009 09:45 PM
jds_06
Jan 18, 2005 09:36 AM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
Etylorcen
Oct 25, 2001 07:31 AM
