SOHC Fuel Pump VS. DOHC Fuel Pump
Old Aug 19, 2003 | 09:13 AM
EG2 SiR's Avatar
Default SOHC Fuel Pump VS. DOHC Fuel Pump
I have already searched and was not satisfied with what I found so,
I have a 95' Del Sol Si Chassis with a B16A Swap... My question is, Will swapping out my SOHC fuel pump (w/79lph) to a DOHC VTEC fuel pump (w/135lph) make a difference? I want to know if it is worth my time and money....
thanks!
Old Aug 19, 2003 | 10:41 AM
EG2 SiR's Avatar
Default Re: SOHC Fuel Pump VS. DOHC Fuel Pump (EG2 SiR)
ttt
Old Aug 19, 2003 | 10:46 AM
Turbogixxer's Avatar
It will run with the stock pump but I highly suggest you upgrade to a bigger pump. If you do not, you run a risk of running lean.
blk_eg4
Aug 14, 2006 04:12 AM
Vtakkk
Feb 22, 2006 07:20 AM
EG2 SiR
Aug 19, 2003 10:14 AM
dropcivc
Sep 19, 2002 05:41 PM
