Injectors
Ok, i was wondering around what horsepower you should think about upgrading injectors...or if its even needed at all? Im gonna be putting down 235 to the wheels hopefully and im gonna be on stock b18a1 injectors/hondata...anyone have some input?
idealy you want to be at 80% duty cylce on injectors. with 178ishwhp on rc310cc injectors i was at 79% duty cycle at WOT
you will run way too lean and have bad spray patters if you are running the injector to hard.
get some 310s and call it a day
austin with his 190whp setup is running 290cc prelude injectors he is above 90% duty cylce. if he went with other injectors his spray pattern would improve and would probably pick up some midrange power.
you will most likely run way too lean with anything below 290cc
im not too familiar with break in period
all gsr/itr/ls injectors are the same. they are 240cc
if you are really going to hit 235whp, then you need bigger injectors
If you are going to be at 235whp all motor 370's - 440's. Injector spray pattern and not maxing out your injecotrs or "over-working" them is a good thing. I had a friend blow out 310's due to this. Running to much pressure to over comp for lack of injector size. Stockish fuel pressure is good.
