Code 80 - Insufficient EGR Flow
Old Aug 19, 2003 | 06:30 AM
Accord_Munch's Avatar
Default Code 80 - Insufficient EGR Flow
Okay Peeps ... my car threw a code 80, for insufficient EGR Flow. I had the EGR Valve assembly replaced about two weeks ago, and a day later the Code came back on. What else can I check without taking my car in (I should have done the Assembly myself).
Thanks.
Old Aug 19, 2003 | 08:22 AM
dcaccord's Avatar
Default Re: Code 80 - Insufficient EGR Flow (Accord_Munch)
Clean EGR ports on IM and EGR distributor?
Old Aug 19, 2003 | 09:18 AM
DrunkNRacer's Avatar
Default Re: Code 80 - Insufficient EGR Flow (dcaccord)
Clean the carbon build-up off the ports with some Carb Spray and Pipe Cleaners (Or tooth picks)..
Old Aug 19, 2003 | 11:22 AM
Default Re: Code 80 - Insufficient EGR Flow (G-villeRacer)
I should have elaborated .... that was done prior to the EGR Assembly being replaced.. There wasn't much carbon buildup.
Old Aug 19, 2003 | 01:17 PM
StimpyBoy's Avatar
Get a Helms and go through the troubleshooting procedure. There's a few other things that control the EGR valve (vacuum tubes, a solenoid, etc). Sometimes you can find the Helms manuals in libraries as well.
Old Aug 19, 2003 | 01:44 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord_Munch &raquo;</TD></TR><TR><TD CLASS="quote">I should have elaborated .... that was done prior to the EGR Assembly being replaced.. There wasn't much carbon buildup.</TD></TR></TABLE>
Have you checked the EGR solenoid valve?
Gebo
Nov 1, 2016 09:09 PM
2point2
Apr 28, 2004 05:51 AM
blackdelslo
Apr 16, 2004 02:31 AM
lakerschamp2000
Mar 7, 2004 02:17 PM
F120man
Aug 26, 2003 05:04 PM
