How to install Autometer gauge - voltage meter?
Old Aug 19, 2003 | 04:34 AM
Fuster_Cluck's Avatar
Default How to install Autometer gauge - voltage meter?
Shell: 93 Civic Cx
Motor: 98 GSR / OBD1 p72 ECU
Just purchased 3 gauges for the Hybrid (oil press / water temp / voltage).
Wondering how to install the voltage meter once it arrives
Picked up this one (ATM-4791):
Thanks for any useful info
Old Aug 19, 2003 | 06:16 AM
WundedSaint's Avatar
Default Re: How to install Autometer gauge - voltage meter? (Hybrid93Hatch)
One wire to ground, another to a switched positive circuit.
rmc
Old Nov 13, 2003 | 06:17 PM
Default Re: How to install Autometer gauge - voltage meter? (WundedSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WundedSaint &raquo;</TD></TR><TR><TD CLASS="quote">One wire to ground, another to a switched positive circuit.
rmc</TD></TR></TABLE>
Going to finally install the gauges this weekend. Where is a close switched positive to the center console?
Thanks!
Old Nov 14, 2003 | 12:28 AM
DCStreetHtch's Avatar
tap the clock harness for power, easiest clip to get to
-Bryan-
Old Nov 14, 2003 | 12:32 PM
LudeyKrus's Avatar
Personally, I would run that gauge straight to the battery's positive post.
I would prefer an accurate voltage level at the battery, and it is proven that you lose a bit of voltage going through the car's electrical system.
Old Nov 14, 2003 | 08:12 PM
mntuner2's Avatar
or i believe there us a switch 12v source on the fuse block.
Old Nov 25, 2003 | 05:05 PM
b20_ed's Avatar
Default Re: How to install Autometer gauge - voltage meter? (mntuner2)
2 Questions, does an ammeter install the same way? And how did you wire up the gauge lighting?
Old Nov 25, 2003 | 06:37 PM
LudeyKrus's Avatar
No; the ammeter basically sits between a large high-current power cable.
And the lighting wires are wired the exact same as the other gauges; on a switched 12V line.
ali7up
Feb 17, 2006 12:18 AM
boostincoupe
Aug 12, 2004 05:36 PM
93_hatch
May 2, 2004 12:49 PM
Fuster_Cluck
May 15, 2003 07:14 AM
