S2000 Start Button needs relay ???
If you burn it out from not using a relay (which won't take very long)...
Gut out the button & mount a 20amp momentum switch behind it. When you push the button, you will then have a switch capable of handling the power. Four years later, this setup still works.
I've installed the switch with a relay so you get the "light up" effect, but the light is so dim, I don't think it's worth it. .02
i have installed it with a relay and it worked... and still works after 2 days
but the illumination is hardly noticeable even at night...
anyone know how to adjust the brightness?
by connecting to something for example
GS8HFL21
Nov 9, 2005 06:56 AM
xcathodex
Audio / Security / Video
34
Mar 1, 2003 03:42 PM
