S2000 Start Button needs relay ???
Old Aug 19, 2003 | 12:32 AM
boszyen's Avatar
Default S2000 Start Button needs relay ???
to those of you who have done this...
do we really need a relay, if yes why, and if i dont use one, what will happen
thanksssss
Old Aug 19, 2003 | 02:29 AM
Darkteg's Avatar
New User
Default Re: S2000 Start Button needs relay ??? (boszyen)
yes it'll need...
if not - kabooom!!! trust me
Old Aug 19, 2003 | 03:54 AM
BudMan's Avatar
If you burn it out from not using a relay (which won't take very long)...
Gut out the button & mount a 20amp momentum switch behind it. When you push the button, you will then have a switch capable of handling the power. Four years later, this setup still works.
I've installed the switch with a relay so you get the "light up" effect, but the light is so dim, I don't think it's worth it. .02
Old Aug 19, 2003 | 05:00 AM
Batoutahell's Avatar
Default Re: S2000 Start Button needs relay ??? (BudMan)
Maybe it depends on the relay you use? Mine has a relay, and the backlighting is fairly bright, very noticeable at night.
Old Aug 19, 2003 | 07:00 AM
Darkteg's Avatar
New User
Default Re: S2000 Start Button needs relay ??? (Batoutahell)
no problems with the light also...
Old Aug 19, 2003 | 11:48 AM
Tweakmeister's Avatar
Default Re: S2000 Start Button needs relay ??? (Darkteg)
http://www.bseries.net article
Old Aug 21, 2003 | 02:33 AM
boszyen's Avatar
Default Re: S2000 Start Button needs relay ??? (Tweakmeister)
i have installed it with a relay and it worked... and still works after 2 days
but the illumination is hardly noticeable even at night...
anyone know how to adjust the brightness?
by connecting to something for example
clubef9
Lighting
Feb 21, 2008 01:26 PM
Hitz.S2K
Honda S2000
Nov 12, 2006 03:23 PM
GS8HFL21
Nov 9, 2005 06:56 AM
xcathodex
Audio / Security / Video
34
Mar 1, 2003 03:42 PM
TypeR 599
Jan 19, 2002 08:46 PM
