dei 520t backup battery question
Old Aug 18, 2003 | 08:36 PM
cw_civic's Avatar
Default dei 520t backup battery question
I just installed a backup battery to my alarm. My question is does the backup battery need to be charged or will it work right away? When I disconnected my car battery my alarm did not go off. So either I installed it wrong, or the battery needs to be charged. Does it charge by leaving the car running for several minutes, or does it charge by arming the car alarm? Thx
Old Aug 18, 2003 | 10:00 PM
hotboi850's Avatar
Default Re: dei 520t backup battery question (cw_civic)
Possibly wired wrong. ARe those things chargable? hmm.
Old Aug 18, 2003 | 10:27 PM
TurboBumblBee's Avatar
sometimes they will require a charge.. if it still doesnt work i think you may have it wired wrong cause once you disconnect the main power to the alarm brain it should trigger the alarm and keep the alarm going off.. if you have never done it may be a little confusing to wire the correct way..
Old Aug 19, 2003 | 12:01 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cw_civic &raquo;</TD></TR><TR><TD CLASS="quote"> When I disconnected my car battery my alarm did not go off. </TD></TR></TABLE>
The alarm won't go off when you disconnect the main battery because the backup battery is supplying the alarm with constant juice. The only thing the backup battery is supposed to do is keep the alarm active so a triggered zone will set it off.
Old Aug 19, 2003 | 04:27 AM
cw_civic's Avatar
Default Re: dei 520t backup battery question (ScareyH22A)
The only thing that I could think of that is wrong is the backup battery has a blue wire that needs to be connected to a negative trigger, and I connected it to my alarm's negative hood pin trigger. Anything wrong there?
p.s: how long does it usually take the battery to charge when driving the car?
Modified by cw_civic at 6:59 PM 8/19/2003
Old Aug 19, 2003 | 05:11 PM
x00gsr's Avatar
should of gotten the revenger siren.
Old Aug 19, 2003 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">
The alarm won't go off when you disconnect the main battery because the backup battery is supplying the alarm with constant juice. The only thing the backup battery is supposed to do is keep the alarm active so a triggered zone will set it off.</TD></TR></TABLE>
your wrong.. it will to set off the alarm.. ive seen it done, installed them like that, and mine does it also.. chances are the alarm will already be going off cause you should have a hood pin also..
Old Aug 19, 2003 | 06:28 PM
ScareyH22A's Avatar
Community Builder
Default Re: dei 520t backup battery question (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">
your wrong.. it will to set off the alarm.. ive seen it done, installed them like that, and mine does it also.. chances are the alarm will already be going off cause you should have a hood pin also..</TD></TR></TABLE>
There's a difference between a backup battery and a backup siren.
Old Aug 19, 2003 | 06:49 PM
cw_civic's Avatar
I installed the alarm myself. The hoodpin and trunk trigger wires arent used. I tried to wire to each, but neither worked. The only thing I could think of now is that the battery needs to be charged, i already driven for 30 minutes but no luck. Maybe I got a defective battery.
btw: This is a dei 520t backup battery. When someone disconnects the main battery the backup battery has a circuit that instantly triggers the alarm making the siren go off. I wired the backup batteries trigger wire to my hoodpin trigger (which was not in use). They are both (-) wires. Does anyone have any idea why it mite not be working?
VI Boost
Audio / Security / Video
18
Dec 25, 2009 06:54 AM
CeeJayy
Nov 12, 2008 06:33 PM
robble36
Jan 8, 2007 04:03 AM
robble36
Jan 7, 2007 06:03 AM
Prod
Jan 13, 2004 01:29 PM
