one brake bleeder bolt seems to be stuck
Old Aug 18, 2003 | 08:26 PM
b17gsr's Avatar
Default one brake bleeder bolt seems to be stuck
Any tricks? It's one of the front calipers. I was able to loosen the other 3 with ease. I tried tapping with a rubber mallet on my wrench, no go.
Old Mar 25, 2006 | 03:49 PM
beav's Avatar
Default Re: one brake bleeder bolt seems to be stuck (b17gsr)
wd 40? liquid wrench? i dunno...just try not to break those threads cuz you might need a new caliper
Old Mar 25, 2006 | 04:15 PM
JDMB20TDA's Avatar
Default Re: one brake bleeder bolt seems to be stuck (beav)
nah if it breaks u can mostlikly drill and tap.
as for preventing this just u could heat it up a little and try and break it loose...
u can also do what guy said and let it soak in prenetrating oil (pb blaster!) not WD 40
Old Mar 25, 2006 | 08:05 PM
Rtzx9r's Avatar
GDD 1%
Default Re: one brake bleeder bolt seems to be stuck (JDMB20TDA)
PB blaster is excellent. Use a torch on the caliper around the bolt, but not on the bleeder itself. YOu want to heat up the caliper to expand the metal, while the bleeder stays normal size.
Just work it and make sure you are turning it the right way!!
LOWLIFEHATCH
25
May 18, 2023 07:14 AM
tommyofyork
Apr 6, 2007 01:53 PM
Essenar83
Jun 18, 2006 12:12 AM
KayOs
Aug 18, 2002 10:35 PM
civicracer1993
Apr 18, 2002 07:50 PM
