Installed new plugs/wires and now have white smoke!
Old Aug 18, 2003 | 06:48 PM
B2FiNiTY's Avatar
Default Installed new plugs/wires and now have white smoke!
'88 CRX Si - stock motor
Just great! I installed new spark plugs and wires. The wires are OEM honda and the spark plugs are the denso ones recommended in the manual.
NO clue what I did wrong but I plan to drive the car tonight. Hopefully it will be ok. The car is a lot more lively due to the new plugs and wires.
Also changed the valve cover gasket and spark plug gaskets.
White smoke emerged from my exhaust right when I started the car. From then on, it smokes more as the rpm's climb.
The car ran fine before the tuneup and no smoking before.
Old Aug 18, 2003 | 06:53 PM
fourthgenhatchB17's Avatar
Just to be sure...double check the part number on the plugs to make sure u have the right ones. Other than that, if what ur sayin is ALL true, then WTF?!
Old Aug 18, 2003 | 07:45 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
when you changed the gasket, make sure you have the spark plug hole grommets so that no oil creeps into the spark plug area.
A little smoke at high rpms is normal due to age because of the headgasket.
But if it is smoking, you must of did something wrong.
A car just doesn't smoke right away
Old Aug 19, 2003 | 01:33 PM
B2FiNiTY's Avatar
Default Re: (MugenHonda)
It smokes at all rpms. I think it has gone away now but I will try driving it again today and update.
1998_4dr_gsr
Jul 18, 2012 04:49 AM
Rtboy10
Sep 22, 2009 08:20 PM
turboteg90
10
Sep 19, 2008 01:06 PM
b16b18
Sep 6, 2006 12:56 PM
jdmeng
Mar 26, 2005 11:18 PM
