funny mid engine rattle after forged internals where put in
Old Aug 18, 2003 | 06:11 PM
jdm_rex's Avatar
Default funny mid engine rattle after forged internals where put in
hey guys..... i have a 94 gsr motor with eagle h-beam rods and wiseco 9.8to1 pistons and it only has 40miles on it and it makes this funny rattle from like the top of block, bottom of motor area...... what would make this happen?
Old Aug 18, 2003 | 06:40 PM
jdm_rex's Avatar
Default Re: funny mid engine rattle after forged internals where put in (jdm_rex)
damn it I ment top of block bottom of head....
Old Aug 18, 2003 | 07:37 PM
Mohudsolo's Avatar
Just when cold or all the time? What prep was done on the cylinders/block? Forged pistons need more clearance due to expanding more from cold to hot than cast ones. This can make them rattle when cold. Of course loose wrist pins could do it too or worn or tapered bores.
The ones I have heard with forged pistons have a light rap or slight knock that goes away as it warms up. If that is not what happens, I would be concerned about clearances in bearings.
Old Aug 18, 2003 | 07:47 PM
poison's Avatar
If it does it when the motor is cold, then it is normal. This is the forged piston 'purr". The pistons are smaller in the cylinder due to the heat inside, and when the engine is a normal operating temp, the pistons expand due to heat to the correct bore and seals up.
If it does it ALL the time, then check timing, make sure your piston/valve clearance is good (should be since you are at 9.8:1 CR).
Old Aug 18, 2003 | 10:12 PM
FLOWZILLA's Avatar
FIRST OFF CHECK UR CYL. WALL TO PISTON CLEARANCES THEN CHECK IF UR PISTONS ARE SILICON OR NON SILICON BASED SOUNDS COULD BE MANY THINGS
killacam661
Jan 20, 2009 09:41 PM
N1 Andy
Oct 12, 2008 06:56 AM
cluelessmale
May 28, 2007 07:43 PM
tuan_turbo_dc4
May 29, 2004 08:52 PM
94si94cx
Apr 7, 2004 06:29 AM
