Need answer quick pleez help
Old Aug 18, 2003 | 05:43 PM
R6Boy69's Avatar
Default Need answer quick pleez help
I have a 97 ITR motor but it came with no waterneck (where the rad hose connects to the cylinder head) and no thermostat housing. So I used the water neck and thermostat housing from a 1st gen B16. Upon further inspection they each have an extra spout coming from them with nowhere to connect them (cause the spouts are not there on a ITR motor). My question is can I just connect the two, or will there be an adverse affect from that? What should I do?
Old Aug 18, 2003 | 05:53 PM
poison's Avatar
Default Re: Need answer quick pleez help (crXBoy69)
It depends on where they go to. But mainly on the main water line (with the thermostat housing), there is nipples on them to lead to the header core inlet. You mainly want to make sure the coolant flows.
Just depends...
Old Aug 18, 2003 | 06:35 PM
R6Boy69's Avatar
Default Re: Need answer quick pleez help (poison)
they dont go to anywhere on the motor, as I said I looked at pictures of a type R motor and these nipples aren't there.
Old Aug 18, 2003 | 07:50 PM
Stripped Honda's Avatar
99-0104
yes it is ok to connect them together you will have no problems
Hybridguitarist
Jan 9, 2017 05:06 PM
dirtygerman
Apr 28, 2013 04:43 AM
Black R
Jan 27, 2009 05:59 PM
jdmsir4dr
14
Jan 12, 2009 06:56 AM
new_climber
Dec 14, 2008 08:50 PM
