CTR Pistons with GSR.
Old Aug 18, 2003 | 04:11 PM
Team 4's Avatar
Default CTR Pistons with GSR.
I did a search.
Can you use the standard bore CTR's with the GSR stock bore?
Old Aug 18, 2003 | 04:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: CTR Pistons with GSR. (REVHARD_EF)
Yes, assuming your cylinder walls are undamaged.
Old Aug 18, 2003 | 06:11 PM
TwoRedEGgs's Avatar
Default Re: CTR Pistons with GSR. (Padawan)
yeah u will just need to rehone the block and if they are used pistons then i would prolly get new rings also. good luck
Old Aug 19, 2003 | 05:43 AM
gsracer170's Avatar
Default Re: CTR Pistons with GSR. (TwoRedEGgs)
what compression would it yield? i head around 12.5 to 1... is this true?
Old Aug 19, 2003 | 06:01 AM
advanracing62's Avatar
Default Re: CTR Pistons with GSR. (maingear)
yes... depending on if the head was milled or block decked.
Old Aug 19, 2003 | 07:23 PM
dz-racing's Avatar
Default Re: CTR Pistons with GSR. (advanracing62)
12.5-1 is getting way up there for 93-94 octane fuel. You might find yourself needing to mix w/100 for street driving. Just from my exp. and my 2 cents
Old Aug 20, 2003 | 01:19 AM
camp1320.com's Avatar
Default Re: CTR Pistons with GSR. (dz-racing)
With CTR pistons in a GSR block with GSR head , i heard the compression was about 13:1 .. They guy that had that set up had to retard his timmming to 12 degress and run 101 or 92 and VP mix only, cus it would ping and knock at higher rpm.
Old Aug 20, 2003 | 08:19 AM
Tweakmeister's Avatar
Default Re: CTR Pistons with GSR. (camp1320.com)
no,
check here: http://www.c-speedracing.com/h...c.php
it's fine. it's very streetable providing you tune the setup.
search, there's easily 300 pages about this.
Old Aug 20, 2003 | 09:51 AM
MaxBoost's Avatar
New User
Default Re: CTR Pistons with GSR. (Tweakmeister)
It's NOT 13.0:1
Take a 10 points off of that, cus it's 12.04:1
Stock bore CTR pistons, stock headgasket, no milling or decking...I ran it fine on pump gas with just a tiny bit of low-end ping, that I easily tuned out later..
Now, if you run .25over CTR pistons in an LS/VTEC, with milled head, then you can easily get 13.0:1, but it's more likely you'll be around 12.7:1 w/o milling and stock headgasket..
Old Aug 20, 2003 | 01:49 PM
Comp97GSR's Avatar
Default Re: CTR Pistons with GSR. (MaxBoost)
Tweak, in the R forum there is a thread about CTR pistons in a C5 and it has been said that compression would be around 12.5. Is that incorrect? I have always figured that CTR pistons in a C1 would be around 12.1.
Old Aug 20, 2003 | 02:25 PM
Suprdave's Avatar
Default Re: CTR Pistons with GSR. (Comp97GSR)
12:1...you shouldnt ping at all on 93...tune that ****.
Suprdave
Old Aug 20, 2003 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Tweak, in the R forum there is a thread about CTR pistons in a C5 and it has been said that compression would be around 12.5. Is that incorrect? I have always figured that CTR pistons in a C1 would be around 12.1.</TD></TR></TABLE>
the GS-R and ITR heads are different. GSR will yield higher compression than ITR with CTR pistons.
I don't know why SgT said to use b16 pistons in an ITR other than for tuning reasons. Depending on where you are the setup is going to need extensive tuning. To me CTR pistons in a B18C1 is the "ultimate" street setup without going crazy.
B18C1 with CTR pistons
https://honda-tech.com/zerothread?id=97301
Also see:
http://www.geocities.com/Motor...s.htm
C-speed calc says 12.05, although I believe it is closer to 12.5
Bottom line: does it really matter? Drop them in and make some power. If you want more, go for more.
Old Aug 20, 2003 | 09:28 PM
yeer's Avatar
ok around mid 12s for the CTR in C1
what about P30 in stock b18c5, cspeed says 11:3:1??????
Old Aug 20, 2003 | 10:06 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF &raquo;</TD></TR><TR><TD CLASS="quote">I did a search.
Can you use the standard bore CTR's with the GSR stock bore?</TD></TR></TABLE>
Yes but anytime your switching pistons, especially a high Compression or FI setup I'd suggest going to the next size up and Boring/Honing the block Vs just honing the block and dropping in some same bore pistons.
Compression with Stock bore or .25 over on a GSR will be about 12.4-12.5:1
Perfectly streetable with 91octane & up,with a little tuning.
Old Aug 20, 2003 | 11:08 PM
Team 4's Avatar
Default Re: CTR Pistons with GSR. (Mike M)
Good call dude!
enokcrx
23
Jul 9, 2013 07:04 AM
jdmhop26
Jun 12, 2011 03:40 PM
Ricextacy
29
Apr 20, 2009 10:53 PM
ALLMOTOR CRX
18
Jun 22, 2007 01:39 AM
akhom
Feb 6, 2002 08:18 AM
