2 subs off a one channel amp?
Old Aug 18, 2003 | 03:42 PM
kitkat77's Avatar
Default 2 subs off a one channel amp?
I have a rockford amp, it's a one channel amp, but i have two subs. I was told that you can do something to make it work. What exactly do you do?
Old Aug 18, 2003 | 05:36 PM
PetroGuyX's Avatar
what's the impediance of your subs? are they single or dual voice coil?
Old Aug 18, 2003 | 09:18 PM
lootchase's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">what's the impediance of your subs? are they single or dual voice coil? </TD></TR></TABLE>
^ once u get that bridging or running them parrallel would be good.
Old Aug 19, 2003 | 06:52 AM
Xsi's Avatar
Xsi
Yes, how many voice coil are your subs and how many ohms each? Also, what ohm load can your amp handle?
Old Aug 19, 2003 | 07:23 AM
kitkat77's Avatar
I don't know too much about this stuff, but on the box it says Impedance: 4 or 8 with symbol after each number.
Old Aug 19, 2003 | 07:29 AM
kitkat77's Avatar
Default Re: (Xsi)
I don't know where to find out about the voice coils that you were talking about. The amp's box says that the maximum power is 400 watts, 4 Ohm Load mono-100watts, 2 Ohm Mono-200 watts. Like I said, I don't know too much about this stuff. If anyone knows a lot about rockford, the amp I have is called the 200M, and the 2 subs I have are Punch Z. I got the subs at the end of last year, and the amp the beginning of this year if that's any help.
Old Aug 19, 2003 | 07:36 AM
Xsi's Avatar
Xsi
Ok, so it sounds like your amp is 2 ohm stable and the sub it dual 4 ohm perhaps.
How many terminals are on the sub? where you plug the wires onto the sub, are there 4 terminals or 2 like a normal speaker?
If there are 4 it is a dual voice coil sub which will give you more options when wiring two of them up.
Old Aug 19, 2003 | 02:39 PM
GeeReg's Avatar
Default Re: 2 subs off a one channel amp? (kitkat77)
I think the box would say DVC if it was dual. Where it says 4 or 8 ohm, are there boxes next to it like one would be checked? I just checked quick and they seem to either come in 4 or 8, not DVC, so I don't know.
Old Aug 19, 2003 | 08:20 PM
kitkat77's Avatar
Default Re: 2 subs off a one channel amp? (GeeReg)
Ok, I just opened the the box. On the back of the sub it says 1.5" voice coil, 4 ohms, and 400 watts max power. I hope that helps some..
Old Aug 19, 2003 | 08:28 PM
kitkat77's Avatar
Also, on the little paper that came in the box, it has like model numbers I guess, and there are two choices for the same sub. I guess that means that it's it varies depending on how many subs are hooked up to one amp. For the two numbers it has nominal impedance of 8 for one and 4 for the other. I opened the box that the amp is in, and it doesn't say anything about using more than one sub, however when I bought it they said it could be used for more than one. I'm just not sure how. Lemme know. thanx
Old Aug 19, 2003 | 08:29 PM
SpeedDreamz.com's Avatar
Sure two-4 ohm v/c woofers give you a 2 ohm load on the amp. I dont believe a Rockford mono amp would have a problem with that.
Old Aug 19, 2003 | 08:30 PM
kitkat77's Avatar
Default Re: 2 subs off a one channel amp? (30psiCiv)
Ok, so now i know it will work, but I still have no clue how to hook it all up. Do most people do it themselves?
Old Aug 19, 2003 | 08:42 PM
How many speaker terminals does the amp have?
Old Aug 19, 2003 | 08:50 PM
kitkat77's Avatar
it has 2, a + and a - .
Old Aug 19, 2003 | 09:04 PM
SImple.
Speaker 1 + to Speaker 2+ to the amp + and the same with the - or negative side.
That is called parallel.
Old Aug 19, 2003 | 09:37 PM
kitkat77's Avatar
Default Re: (jomo7)
why do you say don't do that?
Old Aug 20, 2003 | 12:03 AM
Xsi's Avatar
Xsi
Two 4 ohm subs can be wired in parallel, this will present the amp with a two ohm load which your amp should be able to handle.
Best to wire the subs like this: http://www.jbl.com/car/support...2.asp
Old Aug 20, 2003 | 05:34 PM
kitkat77's Avatar
Default Re: (Xsi)
oh, ok thank you!
teknoracing
Audio / Security / Video
30
Jun 7, 2006 03:42 PM
Dub C
Feb 7, 2006 07:15 PM
PiNoYxRaCeRxRH88
11
Nov 26, 2005 10:35 AM
NACvicSi
15
Oct 20, 2005 12:06 PM
SHystrdyGSRtdy
Sep 8, 2004 12:11 PM
