BLOCK HEAD COMBO????
Old Aug 18, 2003 | 12:54 PM
SLOAZZ95's Avatar
Default BLOCK HEAD COMBO????
WHAT WOULD BE THE BEST BLOCK FOR A Z6 HEAD TO BOLT UP TO??? WHAT WOULD BE THE NEWEST BLOCK THAT A Z6 HEAD WILL BOLT UP TO??? SMOKING AND ITS MORE THEN LIKLY THE RINGS, I WANT TO STAY BASICALLY ALL MOTOR SOHC WITH SOME TUNNING. ITS AN EVERYDAY DRIVER THAT I HAVE ALITTLE FUN WITH AT THE TRACK ON WENSDAYS.
.nate's Avatar
Default Re: BLOCK HEAD COMBO???? (SLOAZZ94)
YOUR CAPS LOCK KEY IS ON.
Old Aug 18, 2003 | 12:56 PM
Chris y0!'s Avatar
Default Re: BLOCK HEAD COMBO???? (IRVTECH)
I THINK A D16Z6 BLOCK WOULD BE P TO THE I TO THE M TO THE P
Old Aug 18, 2003 | 12:58 PM
SLOAZZ95's Avatar
sorry bout the caps key, i am at work and it has to be on for me to work. by the way thanks for the help on the ? buddy.
somone told me a dx block has high compression w/ the z6 head.
Old Aug 19, 2003 | 04:50 AM
SLOAZZ95's Avatar
BUMP
Old Aug 19, 2003 | 06:29 AM
SLOAZZ95's Avatar
Come on people, i cant belive that noone has any ideas or knowledge on this subject. i did a search and it brought up like 800 threads.
Old Aug 19, 2003 | 06:47 AM
sohc_boy's Avatar
i think u should just keep your z6 block and build that. what year dx block are u talking about? the 92-95's are 1.5's and the 96 up are 1.6's. if u do a search u will find quite a bit of info on building up the d-series.
Old Aug 19, 2003 | 09:25 AM
SLOAZZ95's Avatar
Default Re: BLOCK HEAD COMBO???? (sohc_boy)
I am talking about a 96-up block. what i really wnat it for is so that i can get a lower mileage block so i dont have to do rings on my block.
Old Aug 20, 2003 | 07:03 AM
SLOAZZ95's Avatar
THANKS FOR THE HELP GUYS!!! LOL
Old Aug 20, 2003 | 07:09 AM
BauleyCivic's Avatar
Risky Business
are you going turbo or NA?
for turbo...do a d16z6 block for the stronger rods...
for NA...do a d15b7 block with d15z1 (VX) rods and p29 pistons so you can get the high compression
i'm pretty sure LS rods will fit in D-series blocks...just not sure which ones
Old Aug 20, 2003 | 07:29 AM
SLOAZZ95's Avatar
Default Re: BLOCK HEAD COMBO???? (BauleyCivic)
looking for all motor, i will prob just rering my block. when i get it reringed then do i need to get the block polished or bored. and where would i get rings, because they will have to be oversized if i am correct.
Old Aug 20, 2003 | 10:59 AM
sohc_boy's Avatar
https://honda-tech.com/zerothread?id=335078
Old Aug 20, 2003 | 11:52 AM
Average Al's Avatar
d15 from 92-95 have weak rods but when using this block you can reach higher compression. good for when starting of with a dx cx or vx and doing a mini me (good for around 200)
i not sure if z6 fits on a d16y7/y8 (could be wrong)
but for sure a d16y8 SOHC vtec fits on a z6 block
b18a rods fit on to only d16 blocks d16a6, d16z6, d16y7/y8 etc. but with brushing and changing the wrist pin size
if you already have a z6 block might as well get new rings unless you can find a cheap newer better condition d16 block for good price.
the newest block to use would be probably d16y7
Old Aug 21, 2003 | 09:13 AM
SLOAZZ95's Avatar
Default Re: (Average Al)
What do i need to do to the block if i just put rings in it.
skateboard_ej8
Apr 10, 2008 10:06 AM
ex_ricer
Dec 14, 2007 08:54 PM
dkrex001
Sep 6, 2006 07:58 AM
