advantages of a cam gear?
Old Aug 18, 2003 | 11:34 AM
sohcvtec1995's Avatar
Default advantages of a cam gear?
What will a cam gear do for a single cam performance wise? i know that if you advance the gear it will make you quicker, and if you retard it it will make you have better top end. am i right?
Old Aug 18, 2003 | 11:40 AM
Doctor CorteZ's Avatar
Default Re: advantages of a cam gear? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">i know that if you advance the gear it will make you quicker, and if you retard it it will make you have better top end. am i right? </TD></TR></TABLE>
depends.
other things come into play when you start altering the timing of your engine.
Old Aug 18, 2003 | 12:07 PM
civic-4-ges's Avatar
Default Re: advantages of a cam gear? (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">other things come into play when you start altering the timing of your engine.</TD></TR></TABLE>
Isn't that the truth. You will notice a subtle change, more in the advance than the retard. IMHO advance the gear a couple of degrees, that will bring your powerband down a bit and let you have the feeling of a bit more power down low.
onah
May 25, 2007 01:20 PM
mugenpower09
Feb 23, 2007 07:48 AM
BlackHXCoupe
20
Jul 20, 2006 12:16 PM
jdm4drSi
May 12, 2005 02:28 PM
Ignitecivic
Nov 6, 2003 08:32 PM
