out of ideas...getting pissed off
Old Aug 18, 2003 | 09:51 AM
Mush-'s Avatar
Default out of ideas...getting pissed off
For the last few months, whenever I turn the steering wheel left or right I've been hearing crazy squeaking. The same happens, albeit a slightly different squeaking sound, when I creep to a stop or start moving slowly. I've changed all wheel bearings, front control arm bushings etc and I can't rid my car of that horrible *** sound. Any suggestions? Also, I've been hearing a clanging/rattling sound under the car whenever I hit a bump. It's loud, extremely irritating and embarassing when going over bumps. I was thinking that it could be any number of heat shields under the car? HELP?
Old Aug 18, 2003 | 10:20 AM
Perfectionist's Avatar
Default Re: out of ideas...getting pissed off (Mush-)
Did you check for broken front coil spring(s)?
The rattle could be caused by heat shields as you suggest. You just have to get under there and give the exhaust system a thorough inspection.
Old Aug 18, 2003 | 10:34 AM
Mush-'s Avatar
Default Re: out of ideas...getting pissed off (Perfectionist)
mmm i just had the shocks/springs replaced as well.... but i'll definitely give the exhaust system a thorough check....
any ideas about the squeaking with the steering wheel turns and bumps?
Old Aug 18, 2003 | 10:42 AM
TiggsCRX's Avatar
brakes? maybe a sticking pad. my car squeaks when I turn to the right but thats cuz my rear brakes are on thair last 1/4 of the pad and getting lower in some spots
Old Aug 18, 2003 | 10:51 AM
Mush-'s Avatar
Default Re: (TiggsCRX)
haha, i replaced, brake pads, rotors a month or so ago. My brake calipers were seized but they were relubed and stuff so i'mm assuming they're allright? any others?
Old Aug 18, 2003 | 11:11 AM
Mush-'s Avatar
what about a control arm issue?
Old Aug 18, 2003 | 12:37 PM
HGZ's Avatar
HGZ
My car used to rattle a lot whenever i would be at idle or in a drive thru or somethin' and it finally drove me insane, so I got under the car, took off my heat shields from the cat, all the way to the flange, and noticed their were a bunch of little pebbles and rocks that would rattle in between the exhaust pipe and the shield. So I cleaned those out, and put the shields back on. About a month later, the rattling started again, because rocks and pebbles got in there again. So I just said screw the heat shields and left them off. My car wasn't super slammed, so I seldom scraped the pipe on bumps... My friend who works as a Honda mechanic said that the heat shields aren't extremely necessary, so I tossed 'em... I never did hear that rattling again. Unfortunately, I crashed the car and now I'm hoofin' it...
Old Aug 18, 2003 | 01:21 PM
b16_madman's Avatar
Default Re: out of ideas...getting pissed off (hgzee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hgzee &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
/\ this pic makes me want a cage. Dang man. Time to start saving for an autopower.
Old Aug 18, 2003 | 01:36 PM
jisu009's Avatar
Default Re: out of ideas...getting pissed off (B16_madman)
I think it is a broken ball joint.
Old Aug 18, 2003 | 01:58 PM
altoid's Avatar
Default Re: out of ideas...getting pissed off (jisu009)
turn your car off and let teh sucker cool down and then hit the exhaust lightly with a hammer and see if you see anything moving or hear rattling. I've got 2 or 3 heat shields that rattle like a ***** and i checked them out to see if i could fix them but the bolts rusted and i figure the sheilds need to be welded down cuz there nothing where the bolts used to go through
Old Aug 18, 2003 | 06:38 PM
AaronJ's Avatar
Default Re: out of ideas...getting pissed off (altoid)
why would his exhaust cause squeeking when turning?? on my grand am it squeeks just like you are describing, its the rack and pinion going out.
Old Aug 19, 2003 | 06:02 AM
Mush-'s Avatar
Default Re: out of ideas...getting pissed off (AaronJ)
sweet thanks guys, i'll present my mechanic with these options and have them checked out...not before i give it a look tho heh
could it be anything to do with the steering column...seems like it sstarts squeakin the min i turn the wheel.
Old Aug 19, 2003 | 07:42 AM
gocivicgo's Avatar
Do hondas have an upper strut bearing?
If never really noticed btui i know they are bad for squeaking in some north american cars.
Old Aug 19, 2003 | 07:49 AM
Runnerdown's Avatar
I would like to make the balljoint suggestion as well. My accord had a loud squeak when turning and over bumps. Turned out the balljoint was dry even though the boot was still good?!?
Old Aug 19, 2003 | 08:26 AM
vulcandan's Avatar
Default Re: (Runnerdown)
Try these two things:
1. You have power steering and the rack is at full capacity, and that's basically telling you to let off.
2. Check your fender wells. My ef rubs the tires on the frame rails. It's done it since I've owned it.
Old Aug 19, 2003 | 08:53 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hgzee &raquo;</TD></TR><TR><TD CLASS="quote">My car used to rattle a lot whenever i would be at idle or in a drive thru or somethin' and it finally drove me insane, so I got under the car, took off my heat shields from the cat, all the way to the flange, and noticed their were a bunch of little pebbles and rocks that would rattle in between the exhaust pipe and the shield. So I cleaned those out, and put the shields back on. About a month later, the rattling started again, because rocks and pebbles got in there again. So I just said screw the heat shields and left them off. My car wasn't super slammed, so I seldom scraped the pipe on bumps... My friend who works as a Honda mechanic said that the heat shields aren't extremely necessary, so I tossed 'em... I never did hear that rattling again. Unfortunately, I crashed the car and now I'm hoofin' it...
Little Bondo and your set! j/k
Regarding that noise up front, see if your radius rod bushings are all good, and tight.
Old Aug 20, 2003 | 06:28 AM
Mush-'s Avatar
Default Re: out of ideas...getting pissed off (Ef *****)
Word, thanks guys. What ever would I do without honda-tech.com? Wait, I know just what I'd do ... I'd WALK my *** everywhere!!!
Old Aug 20, 2003 | 07:00 AM
turbo sol's Avatar
i am in the same boat as you. I have replaced so much of my suspension it pisses me off that is still does this.
I am goign to replace my frotn calipers and see where that goes. keep me posted if you figure somethign out.
Old Aug 20, 2003 | 07:39 AM
Mush-'s Avatar
Default Re: out of ideas...getting pissed off (turbo sol)
yeah i talked to a guy at kung fu last night and he thought that it could be resulting from a hung-up caliper or something and that they might also be causing the rattling noise
i'll have to check on that too
but i'll keep you posted for sure
Old Aug 20, 2003 | 09:20 AM
BdoubleU's Avatar
What about the rack and pinion? The bushing that the steering column goes through can skweeeeek too!
Old Aug 20, 2003 | 10:57 PM
Mr.Saturn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">
/\ this pic makes me want a cage. Dang man. Time to start saving for an autopower.</TD></TR></TABLE>
Just do what I did and buy it before you have the money, then you have a reason to save all the cash!
Old Aug 22, 2003 | 10:15 AM
Mush-'s Avatar
Default Re: (JoeDaMan)
Thanks a lot guys, I'll be sure to get on this ASAP... no more procrastination.
4tika4
Aug 15, 2016 09:10 PM
crxaddikt
Suspension & Brakes
Oct 22, 2014 09:46 AM
FreshCD5
May 14, 2010 01:17 PM
crxfreak88
May 10, 2009 11:14 AM
Mush-
Aug 14, 2003 10:45 AM
