Black fluid in my clutch resevoir?
Old Aug 18, 2003 | 09:39 AM
B18Redline's Avatar
Default Black fluid in my clutch resevoir?
How often are you supposed to replace or drain your clutch fluid? some of the fluid in the clutch fluid resevoir is black.
thanks
Old Aug 18, 2003 | 09:55 AM
dip-set's Avatar
Default Re: Black fluid in my clutch resevoir? (Redline07)
same way mines was last week when i flushed it..the actual fluid was very dark in color so after flushing my brake fluid i used the rest to flush the clutch resevoir and first i sucked out the old fluid with a baster so i would not have to flush that old grimy fluid thru the lines but after sucking it out of the resevoir i found about 3mm of grimey,mud looking **** at the bottom so i cleaned that all out and then put fresh fluid in then flushed...
Old Aug 18, 2003 | 10:24 AM
B18Redline's Avatar
Default Re: Black fluid in my clutch resevoir? (teg-your-it)
how do you flush clutch and brake fluid and then refill it?
thanks
Old Aug 18, 2003 | 10:44 AM
dip-set's Avatar
ok bare wit me on these instructions..
matter of fact nevermind use these to links to do it..its where i learned how to do it step by step for both...
clutch fluid flushing
http://www.team-integra.net/se...D=644
brake fluid flushing
http://www.team-integra.net/se...D=642
and just in case u need this one for brake bleeding..
http://www.team-integra.net/se...D=417
good luck
Old Aug 18, 2003 | 10:56 AM
Big Teggie's Avatar
I try to flush it every 10,000 miles or so. It is probably over kill, but isnt really that hard to do.
globy123
Sep 27, 2009 05:32 PM
superhypie
Aug 30, 2008 05:56 PM
shortlid
Apr 14, 2007 09:20 AM
Dc2 FrEaK
Dec 8, 2006 09:55 AM
lude98SH
May 20, 2006 12:30 PM
