Where to get test pipe cats?!?!
Old Aug 13, 2001 | 07:46 AM
kikkoboyie's Avatar
New User
Default Where to get test pipe cats?!?!
hey i really really really really want a testpipe cat for my 00 teg ls.... if anyone knows where to get one pleaseeee share.... preferably one that bolts right on and replaces the stock catt......
Old Aug 13, 2001 | 07:54 AM
H23 Power's Avatar
Default Re: Where to get test pipe cats?!?! (kikkoboyie)
http://www.autocarparts.com sells a comptech test pipe
Old Aug 13, 2001 | 08:03 AM
bigTom's Avatar
Default Re: Where to get test pipe cats?!?! (01GSR)
go to home depot... buy a long pry bar... then go under your car... take the cat off... and get to work...
Old Aug 13, 2001 | 08:09 AM
kikkoboyie's Avatar
New User
i went to the site, it says, "need to plug o2 sensor," anyone know how to do that?
Old Aug 13, 2001 | 08:15 AM
H23 Power's Avatar
no you don't, i think that is only if your car is not obd2...cause obd2 cars have the o2 sensor in the CAT...
Old Aug 13, 2001 | 08:23 AM
kikkoboyie's Avatar
New User
we both hav the o2 sensor... i thought all 96+ tegs were obdII? u hav 01gsr? well.... im sure i have an o2 sensor....
blah
u use the testpipe on ur 01 gsr, with no sensor hung up?
Old Aug 13, 2001 | 08:31 AM
H23 Power's Avatar
yeah, i know you have obd2...thats why i said you won't have plug the o2 hole...because you will use it...
i haven't gotten the testpipe yet...but i asked them, it does have the hole for the o2
Old Aug 13, 2001 | 08:44 AM
Rory Breaker's Avatar
Kikko - IM me.
Old Aug 13, 2001 | 09:29 AM
b20b's Avatar
New User
Default Re: Where to get test pipe cats?!?! (newgsrdriver)
OBD2 has 2 o2 sensors. One in front of the convertor on the down pipe, and a second one directly in the converter at the rear. If you put the test pipe in, your going to throw a CEL. OBD1 are ok, but on the OBD2, the readings will be off and will be put immediately in to limp mode. I wouldn't suggest doing it with your car. The best way to do it would be to convert it to a OBD1 first. But hey if you really want to do it, give me call (301)946-5521. I have Meineke shop in Kensington. Should be about 20 mins away from you. Talk to NEWGSRDRIVER, he knows where I'm at. I can make one for you.
[Modified by b20b, 10:31 AM 8/13/2001]
Old Aug 13, 2001 | 09:34 AM
bhcvc's Avatar
Email Dan at http://godspeed.hack.net (his email's on there). He carries OBD2 test pipes that have a bung welded on for the O2 sensor. There's also some cat material in the bung so your CEL doesn't come on. Very good cats. Otherwise, if you don't care if your CEL comes on, then just go to a muffler shop and have them make you a pipe with flanges for $30-$40...but with the CEL constantly on, you won't know if there are other problems.
Old Aug 13, 2001 | 08:27 PM
kikkoboyie's Avatar
New User
Default Re: Where to get test pipe cats?!?! (bhcvc)
i talked to god a while ago, he said his o2 pipes only bolt on to a jdm header? im not trying 2 get a jdm header.....
Old Aug 13, 2001 | 08:33 PM
Chris's Avatar
Its real hard to find someone that makes a test pipe ant smaller than 2.5".
Go to a few muffler shops and ask nicely, after you make sure to tell them its for racing only.
roc0487
Dec 26, 2008 08:51 AM
bloodydc2
Jul 18, 2006 02:25 PM
IntegraCF21
Sep 24, 2005 04:42 AM
Toldge
Jul 13, 2005 12:40 PM
integranator
Jul 16, 2003 10:51 AM
