HF slotted rotor's?
Old Aug 18, 2003 | 07:33 AM
AgentJam's Avatar
Default HF slotted rotor's?
Anyone know who or if anyone makes moderately priced (or any price) slotted rotors for an 88 CRX? I've seen them for the other models but not the HF...
Old Aug 18, 2003 | 05:07 PM
AgentJam's Avatar
Default Re: HF slotted rotor's? (AgentJam)
last call...
Old Aug 18, 2003 | 05:27 PM
EL Vap133's Avatar
have you tried eBay?
Old Aug 18, 2003 | 05:29 PM
AgentJam's Avatar
yep, only finding stuff for Si and Dx
Old Aug 18, 2003 | 09:26 PM
Stupid Ass's Avatar
The DX should fit? Right?
Old Aug 18, 2003 | 11:10 PM
turbohf's Avatar
Default Re: HF slotted rotor's? (MooreVTEC)
just swap over DX/Si brakes. you can find that **** pretty cheap. if your near seattle i will hook you up with some calipers for cheap...
btw: Si/DX calipers and rotors (you need to swap them both) will bolt up fine, no mods 'bolt on mod'
Old Aug 19, 2003 | 02:28 AM
AgentJam's Avatar
How about rear brakes? are the HF drums, wheel cylanders and shoes different from the Si/DX on them as well? I just found 89 Si shoes/wheel cylanders for real cheap and i'm gonna need them for my HF as well but i dunno if they will fit my HF rear. Thanks
Old Aug 19, 2003 | 11:09 AM
turbohf's Avatar
those should be the same...
Old Aug 28, 2003 | 06:45 PM
AgentJam's Avatar
Default Re: HF slotted rotor's? (turbohf)
OK i just got the calipers in the mail from a junk yard a few hours away for $55 shipped. Got a few questions though...
1) I only got the calipers from them, no mounting brackets or anything...just the caliper with piston in it. Is this all i need (besides Si/Dx rotors) to do the swap? Or did i get screwed and need to find some Si/Dx mounting brackets for the calipers.
2) The rubber surround on the piston is worn through in some spots. Is this bad? does the surround actually protect the brake fluid from leaking? I don't see any sings of leakage and assumed that the surround wasn't tight enough to actually provide a seal even if it wasn't damaged.
THANK YOU!
Charlie Moua
Mar 23, 2010 09:09 AM
Si2See
14
Apr 25, 2005 12:02 PM
jmr302
Aug 6, 2004 06:43 AM
rice_classic
Jan 28, 2003 11:35 PM
MOCrxHf
Jul 31, 2002 09:51 PM
