what is wrong with my clutch? slave/master cylinder?
Old Aug 18, 2003 | 06:09 AM
T3T495GSR's Avatar
Default what is wrong with my clutch? slave/master cylinder?
been goign on for days now and keeps getting worse.
the clutch pedal wants to stick to ground when you push it down and not come back up wiht much spring, unless you keep pumping it. fluid is full too
Old Aug 18, 2003 | 06:30 AM
4U2NV's Avatar
Default Re: what is wrong with my clutch? slave/master cylinder? (T3T495GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">been goign on for days now and keeps getting worse.
the clutch pedal wants to stick to ground when you push it down and not come back up wiht much spring, unless you keep pumping it. fluid is full too</TD></TR></TABLE>
This once happened to Flamenco-T, except his fluid was completely gone... After filling it, we had to *burp* the system to get all air bubbles out to build pressure... Did you have to re-fill your brake fluid when it first happened...? If so, your problem may lay there... If not, your master cylinder may be bad...
Old Aug 18, 2003 | 06:38 AM
Mt3c's Avatar
25 Year Member
yes, try bleeding the lines. It works just like a brake bleed.
also, check if your master cylinder is bad. take a look under the dash, and right above the clutch pedal. if there's fluid there, your clutch master cylinder is bad.
Old Aug 18, 2003 | 07:38 AM
Rory Breaker's Avatar
Default Re: what is wrong with my clutch? slave/master cylinder? (Mt3c)
Sounds like air in the lines. Also like recommended above, check for fluid under the dash around the MC.
Old Aug 18, 2003 | 01:08 PM
IntEGNYC's Avatar
Default Re: what is wrong with my clutch? slave/master cylinder? (newgsrdriver)
I just bled the clutch fluid last weekend.
The clutch pedal was soft, then it failed completely. A few minutes of pumping brought back the pressure. Luckily my friend who was testing the car only took the car locally. Else we would have had to get a tow truck to go on the highway
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
m3 boostin
May 30, 2007 01:20 PM
itsJDMyo
Oct 24, 2005 05:02 PM
Slow Egg
Feb 11, 2004 10:10 AM
lo0nY
12
Jan 28, 2004 02:15 PM
