LS engine into a GSR body (tried searching!!)
Old Aug 18, 2003 | 05:45 AM
bitzbp's Avatar
Default LS engine into a GSR body (tried searching!!)
I want to put my JRSC'd LS motor (its OBD2) into a 98 GSR chassis. What problems would I encounter?
Do I just swap the ECU's? Or is there some wiring changes that need to be made?
Please help me out if you know.
Old Aug 18, 2003 | 07:03 AM
SiR831's Avatar
Default Re: LS engine into a GSR body (bitzbp)
I'm thinking you should be fine with using the GSR harness. Leave the vtec related wires alone and use the LS ecu. Someone correct me if i'm wrong!
Old Aug 18, 2003 | 08:30 AM
4U2NV's Avatar
Default Re: LS engine into a GSR body (SiR831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking you should be fine with using the GSR harness. Leave the vtec related wires alone and use the LS ecu. Someone correct me if i'm wrong! </TD></TR></TABLE>
I'm pretty sure you're right... There will be some extra plugs such as VTEC solenoid, and secondary butterflies that won't plug in, but everything should run fine...
Old Aug 18, 2003 | 12:24 PM
92VtecTeggy's Avatar
leave the vtec wires unplugged and use a LS ecu. one question though....why put a non vtec motor into a vtec car? i know it's charged and all but i'd put another gsr motor in it. but thats my opinion. good luck
Old Aug 18, 2003 | 12:55 PM
Havokmkr's Avatar
Default Re: LS engine into a GSR body (92VtecTeggy)
Save your money from the engine swap and have the JRSC modified to fit the B18c.
Old Aug 18, 2003 | 08:39 PM
thrty8street's Avatar
Default Re: LS engine into a GSR body (Havokmkr)
put a vtec head on the LS motor and everyone should be used.
Old Aug 18, 2003 | 09:14 PM
AWDxBOOST's Avatar
y a gsr shell....
y not the more lightweight rs?
Old Aug 18, 2003 | 11:48 PM
5spdIntegra's Avatar
Default Re: LS engine into a GSR body (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">put a vtec head on the LS motor and everyone should be used.</TD></TR></TABLE>
That will run for about 10,000miles.
Old Aug 19, 2003 | 05:41 AM
bitzbp's Avatar
Default Re: LS engine into a GSR body (5spdIntegra)
Ok well I am getting a good deal on a gsr shell. Right now I have a beat up 94 Ls that I dropped my JRSC motor an new tranny into. So I am gonna just swap the motor and tranny into this car cause its much cleaner and its cheap to do. When I get more money I would like to get a gsr swap or maybe go with an unreliable LS/VTEC
Do you think I could leave the LS engine harness and just plug it into the GSR chassis harness and then use the LS ecu? I just figured there would be wires that just won't go anywhere on the chassis harness, but all the neccessary wires would still be in the right place for the LS engine harness? If anyone has a clue hit me back, thanks
Old Aug 19, 2003 | 03:25 PM
bitzbp's Avatar
Anybody anybody?
Old Jun 9, 2012 | 03:46 PM
villc713's Avatar
Default Re: LS engine into a GSR body (tried searching!!)
Everything would be fine no matter which way you do it.
Old Jun 9, 2012 | 05:34 PM
collkid's Avatar
WOW. This is from 2003!!!! Almost 10 years old! Villc, you are on your second post. Should probably check dates before you start posting.
frostdc25
Mar 7, 2013 02:56 PM
lsturbo*
Aug 4, 2006 07:55 PM
badassteg97
Jan 25, 2006 04:01 PM
advanced3degrees
May 12, 2003 08:43 PM
