oil catch can setup for Ls/Vtec
Old Aug 17, 2003 | 09:38 PM
jdm_integ's Avatar
Default oil catch can setup for Ls/Vtec
just like the topic says....i did a search and on all the post no one said what motor or setup they had. i plan on getting a greddy catch can, and i need to know how it goes....im thinking it would all be the same. sorry for the stupid question. thanks in advance
Old Aug 18, 2003 | 03:08 PM
EF_LSVtec's Avatar
Default Re: oil catch can setup for Ls/Vtec (jdm_integ)
what it does is simply catch unwanted stuff in your oil that gets recycled back. I would assume that if it works for FI cars, it'll work just as well for NA's. I'm thinking of getting one myself but I've noticed from my friends weekend race car that he actually fills the Greddy reservoir quick. I'd hate to keep on draining that thing since I'm using my car daily and can't afford to run out of oil on my lsvtec. I change my oil before it gets real dirty anyway so I think that's good enough for me. Just my 2 cents.
Old Sep 8, 2003 | 05:57 PM
Rukusmasta2's Avatar
Default Re: oil catch can setup for Ls/Vtec (EF_LSVtec)
is a catch can needed on a ls/vtec NA
Old Sep 8, 2003 | 06:11 PM
WOTTEG's Avatar
Default Re: oil catch can setup for Ls/Vtec (Rukusmasta2)
They will benefit any performance engine as oil vapor in your intake charge has a "leaning" effect.
I know I prevent a lot of oil from entering my LS with the original ENDYNE setup.
Old Sep 8, 2003 | 06:37 PM
BauleyCivic's Avatar
Risky Business
Default Re: oil catch can setup for Ls/Vtec (WOTTEG)
you can run the stock PCV system if you have a b18a block, because they have the air water seprators on the back of the block and the pcv system mimics the pcv system that is on the back of all of the DOHC VTEC motors.
now, the b18b blocks is a diffrent story. they have no air water seprator on the back so they have a completely diffrent pcv system as compared to its vtec counterpart. What i did for my motor is that i ran a pcv system similar to Endyn's 2.0 monster.
See here i have a b18b block, i have the vented gas going out of the filter, i do not run this set up anymore, because of the horrible smell at stop lights. i now have a pcv filter that sits right where this filter sits on the top of the catch can, with a vacum hose coming off it going to the intake manifold. i dont think i have any pictures of it. anyway if you have any questions PM jazzyfoo (thats me, i am on my buddies screen name right now)
-sander
Old Sep 9, 2003 | 02:02 AM
indomotor's Avatar
Default Re: oil catch can setup for Ls/Vtec (BauleyCivic)
Endyn's breather kit I'm running it plus another one(cusco)for the 2 from valve cover.Unless you're planning to make alot of power 2 catch cans are over kill.
Old Nov 13, 2003 | 05:43 AM
99lsvtecauto's Avatar
did u get ne pics of your new setup did that work better
Old Nov 15, 2003 | 01:03 AM
EGtoDC2's Avatar
i'll have to remember this. thanks for the tip of LS catch can install.
Old Nov 15, 2003 | 07:11 AM
89hatchb18a1's Avatar
im stupid can you empty the stock one ??????
Old Dec 28, 2003 | 08:21 PM
vu337's Avatar
how do you run the hoses for a b18c1 with a turbo
Old Dec 28, 2003 | 08:34 PM
Risky Business
Default Re: oil catch can setup for Ls/Vtec (vu337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vu337 &raquo;</TD></TR><TR><TD CLASS="quote">how do you run the hoses for a b18c1 with a turbo</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=377208
Old Dec 28, 2003 | 09:19 PM
eg_type_r93's Avatar
but oil vapors in the intake system can reduce your octane
high compression ?
Old Dec 29, 2003 | 08:43 AM
sander's Avatar
2.7(p/t)
Default Re: oil catch can setup for Ls/Vtec (eg_type_r93)
FYI:
I get alot of **** for running the set up that is pictured above. But i must insist this set up is only nessesary for OBD II b18b blocks. Because i have no stock pcv system, with out this i was blowing oil out my valve cover gasket because all the pressure was building up at idle when the pressure had no place to go.
-sander
Old Dec 29, 2003 | 05:48 PM
gamakichi77's Avatar
Default Re: oil catch can setup for Ls/Vtec (sander)
instead of oil catch cans, can i use an oil cooler which is more efficient?
Old Dec 29, 2003 | 10:02 PM
92TypeR's Avatar
FSAE
Default Re: oil catch can setup for Ls/Vtec (acidburns_di)
You can go ahead and read about my install and see how it is beneficial on the track:
https://honda-tech.com/zerothread?id=622794
An oil cooler + catch can would be the best. One doesnt help the other, its the positive crankcase pressure that causes the blowby that the catch cans are used for, not oil temps.
Old Dec 29, 2003 | 10:22 PM
Default Re: oil catch can setup for Ls/Vtec (92TypeR)
thanks for ur info pal
jfoster
Dec 11, 2005 10:32 PM
BrokenLimits
Feb 3, 2005 08:37 AM
pootie.teng
Apr 8, 2004 05:31 PM
jdm_integ
Aug 18, 2003 11:26 AM
