Acceleration
Old Aug 17, 2003 | 08:44 PM
SilverSoccerMan's Avatar
Default Acceleration
my friend has a civic ex 98' automatic and he was wondering how to make the acceleration faster? any advice needed, ill check back then relay the stuff to him
Old Aug 17, 2003 | 08:54 PM
blackhatchy's Avatar
Default Re: Acceleration (SilverSoccerMan)
why dont you try looking around a little bit? you may find something useful.
better yet, search.
to keep it OT, get a manual tranny.
Old Aug 17, 2003 | 08:57 PM
MrIllegalX's Avatar
LMAO. this has to be a fake question, at least I sure hope it is.
A 98 automatic? prepare to spend lots of $$$. just go down to your local import shop and tell them you want nawzzzz. they'll hook it up!
Old Aug 17, 2003 | 09:30 PM
Default Re: (MrIllegalX)
i told him he should just buy a new freaking car, but he dosent have the money and also wanted to know if an auto to manual switch would be worth doing
Old Aug 17, 2003 | 10:13 PM
UnrealSpeed's Avatar
Default Re: (SilverSoccerMan)
I dont know if its possible, but he can swap a 5th gen AT tranny. I had a 95 Civic EX coupe back in the day with a turbo set up, but b4 I went turbo it would out shift the 6th gen AT's cuz they use their own ECU to shift the Tranny. 5th ges dont. Or he can get a Torque converter.
Old Aug 17, 2003 | 10:31 PM
tominos's Avatar
manual tranny would be the way to go. but might be more trouble than its worth.
Old Aug 17, 2003 | 10:45 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverSoccerMan &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a civic ex 98' automatic and he was wondering how to make the acceleration faster? any advice needed, ill check back then relay the stuff to him</TD></TR></TABLE>
https://honda-tech.com/zerosearch this may help
Old Aug 18, 2003 | 12:59 AM
Tad's Avatar
Tad
i have dsl
can you tell me where to download useful information?
Old Aug 18, 2003 | 03:37 AM
The HamsterBall's Avatar
couldn't he just swap a good motor (H22/B18c/etc) motor into it and put the 5spd on the car that comes with the swap?
i mean.. that will make his car much faster.
but it's a lot of money
so i'm saying.. if he can consider a motor swap, why doesn't he just wait till then to swap the motor and the 5spd tranny instead of swapping a civic tranny right now..
Old Aug 18, 2003 | 05:48 AM
xXx Justin xXx's Avatar
Default Re: Acceleration (HamsterBall)
there is A LOT more to it than just swapping the tranny. you have to use an ecu from a manual, get the pedal cluster from a manual, get a flywheel, clutch, tranny, shift linkage, shifter, ****, boot, mounting brackets for the shift linkage and stableizer bar, a clutch master cylinder + resivoir. run the hydrolic line to the slave cylinder. automatic and manual axels might be different? not really worth it just to make a 5spd. sell his civic and buy something more useful to start with
MtbikingKing
Jul 30, 2005 03:29 PM
w
11
Apr 20, 2005 09:01 AM
XpLiZiT
33
Mar 6, 2005 10:17 PM
cambopheonix56
May 21, 2004 05:27 AM
ExAcc
Sep 6, 2002 05:52 PM
