pressure loss in clutch system
Old Aug 17, 2003 | 04:30 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default pressure loss in clutch system
I just replaced my clutch and got everything back together but now there's a problem with the hydraulic system. It tends to stick to the floor but when you pump the clutch pedal, pressure returns and the car shifts fine. I replaced the slave cylinder twice so this doesn't appear to be the problem. Do you think i have air in the line? I bled the **** out of it for a long time last night and today. Please help
Old Aug 17, 2003 | 05:12 PM
MEANB18's Avatar
Default Re: pressure loss in clutch system (PreIudeSI)
oops my bad, how did you bleed it?
Old Aug 17, 2003 | 07:08 PM
PreIudeSI's Avatar
Default Re: pressure loss in clutch system (MEANB18)
the bleeder valve located on the slave cylinder. Hook up an 8mm wrench to it, hook up a tube to the nipple, have somebody sit in the driver seat and loosen the bleeder, have them push in the clutch, tighten bleeder, clutch out. Loosen bleeder, Clutch in... tighten bleeder, clutch out... etc. Any ideas? I think it's just some air in the system... i hope
Old Aug 17, 2003 | 08:16 PM
Dan GSR's Avatar
how much fluid did u go thru?
if you replaced the slave cylinder....u may have a bad clutch master cylinder
Old Aug 17, 2003 | 08:17 PM
Dan GSR's Avatar
Default Re: pressure loss in clutch system (Dan GSR)
do you have a lot of fluid on your firewall near your clutch pedal assembly?
under the steering column
Old Aug 17, 2003 | 08:56 PM
PreIudeSI's Avatar
no fluid near the master cylinder, i replaced the **** out of it about a week and a half ago. Since then, i haven't driven it. My throwout bearing went bad and i just decided to replace the clutch but before i knew it was the t/o bearing, i thought it could be a problem with the master or slave cyl, so i replaced them both. I bled about a 32oz bottle worth of brake fluid (actually a little less). If it was an air bubble shouldn't it have come out when i bled it... could an air bubble be caught in the master cylinder?
Old Aug 17, 2003 | 09:46 PM
Dan GSR's Avatar
try this way.....pedal in...open bleeder......close bleeder pedal up
opening first can possibly let air into the system....
strange though...u changed everyting and your still losing pressure
may be a stupid question but what are you using for the clutch fluid?
i say its stuipd but my friend used gear oil in his
also have you tried adjusting the push rod on the clutch pedal assembly?
Old Aug 17, 2003 | 10:07 PM
PreIudeSI's Avatar
I don't think that your method will work but i'll try it any way. I bled it for like 10 mins straight earlier. I'm using dot 3 brake fluid of course. I haven't tried adjusting the pushrod assembly on the pedal assembly but it's definately a loss of pressure. I took it for a 20 mile test drive tonight and it's fine as long as you pump the clutch pedal once or twice. If you're just cruising down the road for around a minute or so and you go to push in the clutch, there isn't enough pressure to actuate the clutch. If you let the pedal out and then push it in again, pressure returns.
Old Aug 17, 2003 | 10:09 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that your method will work </TD></TR></TABLE>
this is how i bleed everything....clutch and brakes
Old Aug 17, 2003 | 10:12 PM
PreIudeSI's Avatar
alright i'll check it out. so let me know if i'm getting you right here... clutch in, loosen bleeder then tighten bleeder then clutch out? then what?
Old Aug 18, 2003 | 11:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">alright i'll check it out. so let me know if i'm getting you right here... clutch in, loosen bleeder then tighten bleeder then clutch out? then what?</TD></TR></TABLE>Then repeat, I imagine. When I do it the pedal doesn't come up by itself. I loop a string around it so I can pull it up.
This way you're making the slave piston move each time. This helps free up any air bubbles that are 'stuck' inside the slave. Sometimes it helps to rap on the slave with something to dislodge bubbles. Someone suggested that for brakes & it should work here too...
Old Aug 18, 2003 | 11:34 AM
MEANB18's Avatar
Default Re: pressure loss in clutch system (JimBlake)
Hey, also you might want to check all of your clutch pipes... I actually had a crack in one of my clutch pipes somehow, and it leaked a lot of the fluid out, and I unfortunately found out at a stop light at a busy intersection in Des Moines.
Old Aug 18, 2003 | 12:12 PM
sracing's Avatar
your clutch master cylinder might be leaking!!!check it out...
Old Aug 18, 2003 | 12:46 PM
PreIudeSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">no fluid near the master cylinder, i replaced the **** out of it about a week and a half ago.</TD></TR></TABLE>
Old Aug 18, 2003 | 01:11 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, also you might want to check all of your clutch pipes...</TD></TR></TABLE>Yes. Especially the rubber hose part just near the slave. It might be ballooning up, then the slave never gets the pressure...
Old Aug 18, 2003 | 10:58 PM
PreIudeSI's Avatar
i don't believe i have any "rubber hose" parts near the slave. I took it somewhere today to get pressure bled and they bled some air out of the line but it still isn't 100%. i'm thinking that honda sold me a bad master cylinder or somethin. Oh well it's driveable and i have to make the drive from AZ to los angeles tomorrow so it'll make it. I just won't be able to work on it over there because i don't have any tools at my apartment. I'll probably just end up taking it to this cool old japanese guy with a honda shop about 2 miles away from where i live. He did my brake master cylinder when it went out and i had no time or tools during the school year to change it myself.
Old Aug 19, 2003 | 03:58 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">i don't believe i have any "rubber hose" parts near the slave...</TD></TR></TABLE>Gotta have it somewhere. I don't have a Prelude... but the engine moves too much for an all-steel line. On my Integra, there's a steel line about 10" long from the slave to a bracket on the transmission. Then there's a rubber hose over to a bracket on the fender, where it goes back to steel line.
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
AccordEx1995
Jun 15, 2004 04:24 PM
95excoupe
Dec 12, 2003 01:18 PM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
