ECU PROBLEM???
Old Aug 17, 2003 | 02:48 PM
TRhatchCRAP's Avatar
Default ECU PROBLEM???
Just replaced my Knock Sensor, reset ecu and it is still throwing the code. I double checked the Hasport Vtec sub harness I have, everything is good. Can it be a bad ECU? Running a PR3. Please Help! Thanx...Later,
Old Aug 17, 2003 | 06:56 PM
onePOINTsix's Avatar
Default Re: ECU PROBLEM??? (LunSpeedCRX)
engine?? i'd say your best bet is to find a non-knock sensored ecu or get it chipped with a chip that has knock disabled, i can burn you the chip for like $4 when my chip burner gets here
Old Aug 17, 2003 | 08:32 PM
Default Re: ECU PROBLEM??? (Sideout)
Sorry, it's a JDM B16 in an 91 CRX Si. I am hunting for a new ECU right now. Any other ideas??? Thanx...Later,
Old Aug 18, 2003 | 01:49 PM
BUMP^^^
Old Aug 19, 2003 | 04:24 PM
BUMP, anyone???
Old Aug 27, 2003 | 01:41 AM
nominous's Avatar
With the PW0 if you place a 1K resistor between ground and the knock sensor input at the ECU (cut the wire at the ECU to be sure) then it wont throw a code for no knock sensor.
Old Aug 27, 2003 | 07:01 AM
EF_LSVtec's Avatar
Default Re: (nominous)
I'm having the same problem myself. 3 times I took my car for dyno-tuning, first there's knock sensor code, 2nd no code, then 2 weeks ago, code 23 is back. I even ran a separate wire from the knock sensor directly to the ecu, still no luck. btw, I'm running a pr3 w/ stage 2 hondata. To hopefully finally fix this, I'm in the process of replacing my hasport wire-harness with stock Si and rewire. The Hasport wiring looks really old and the wires crack everywhere. Then I'm converting to obd1 (have all pieces now except for obd1 distributor) and disable knock sensor. PR3/stage 2 hondata doesnt have a disable option for knock sensor. Anyway, sorry for the OT...I'll post the results before I convert to obd1 if I somehow fixed the problem by just rewiring.
InEK
20
Apr 10, 2006 09:03 PM
acclude-vtec
Jan 2, 2006 11:00 AM
ninkei
Nov 15, 2005 04:45 PM
E-brake or Handbrake
Jun 15, 2004 11:58 AM
shadowstylz
Sep 17, 2003 06:05 AM
