Car wont start after camshaft installation...HELP!!!
Old Aug 17, 2003 | 02:34 PM
The OEMobile's Avatar
Default Car wont start after camshaft installation...HELP!!!
Thought i'd post here becuase this is where i usually post. We installed itr camshafts in my 99 b16 head. After we got everythig back together the car cranked but it wont start. I have no idea what is wrong. Any information will really really help.
Old Aug 17, 2003 | 02:40 PM
EG2 SiR's Avatar
Default Re: Car wont start after camshaft installation...HELP!!! (The OEMobile)
timing, timing, timing...... Did you check? It is a good sign that you did not hear anyting collide!
Old Aug 17, 2003 | 02:43 PM
ejprimo's Avatar
Default Re: Car wont start after camshaft installation...HELP!!! (EG2 SiR)
sounds like timing to me. when you crank the motor does it sound like what it used to b4 you installed the cams?
Old Aug 17, 2003 | 03:22 PM
schlack's Avatar
Default Re: Car wont start after camshaft installation...HELP!!! (ejprimo)
check to make sure your firring order is right that hapened to me once.
Old Aug 17, 2003 | 04:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">timing, timing, timing...... Did you check? It is a good sign that you did not hear anyting collide!</TD></TR></TABLE>
How do you check the timing? Doesn't the motor have to be running thats when I have checked mine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">sounds like timing to me. when you crank the motor does it sound like what it used to b4 you installed the cams?</TD></TR></TABLE>
Yea, it sounds normal. I have no idea what to do?
Old Aug 17, 2003 | 04:43 PM
Terry.Ho's Avatar
Yea the motor has to be running to check the timing so jsut play with the distributor a little and see if you can get it to fire.
Old Aug 17, 2003 | 04:51 PM
milo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The OEMobile &raquo;</TD></TR><TR><TD CLASS="quote">
you're talking about the ignition timing....make sure the crank pulley is lined up correctly at TDC, so as the cams
Old Aug 17, 2003 | 05:05 PM
tek_civic's Avatar
Default Re: Car wont start after camshaft installation...HELP!!! (milo)
ya i don't think ignition timing has much to do with it here, unless its 180' off, are you sure you put the intake(i think) cam in to where it rotates the dist in the right order? maybe you have it in 180' wrong. i would check the crank timing first though. make sure the #1 cyl is at TDC and then check that the camshaft sprokets are pointing to their corrisponding marks, if not rotate the engine again so that the #1 cyl is back at tdc as it might have been at BTDC before.
1987CRXSi
Dec 29, 2004 07:12 AM
Skank_aSS_Dara
Nov 14, 2004 04:42 PM
kaoss_11
10
Aug 22, 2004 06:28 PM
The OEMobile
Aug 17, 2003 04:42 PM
b20ek
Jul 6, 2003 08:04 PM
