crx hf to b16a1 vacuume problems?? please help
Old Aug 17, 2003 | 02:23 PM
crx1856's Avatar
Default crx hf to b16a1 vacuume problems?? please help pics inside
i put a b16a1 in my 89 crx hf. i don't know how to conect the vacume lines. there are 4 running off the map sensor assembly on the fire wall and only 2 on the intake manifold and i know one goes to the black canister on the fire wall. how do i hook up the other 3 and which one goes to the throttle body? can someone please post pics or a diagram or explain to me in detail what i need to do. here's a pic if anyone can help me out. i need to know where 1-4 goes and where the line off the fpr goes. #1 is capped off.
Modified by crx1856 at 5:18 PM 8/17/2003
Old Aug 17, 2003 | 04:18 PM
crx1856's Avatar
Default Re: crx hf to b16a1 vacuume problems?? please help pics inside (crx1856)
anyone?
Old Aug 18, 2003 | 08:45 AM
crx1856's Avatar
i tee'd 3/4 and ran it to the throttle body.#2 i left alone running to the black canister, and i have my fuel pressure reg running to the port on the back right side of the intake manifold. i'm still getting a little bit of a bouncing idle and my cold start revs to 2k. can anyone clear this mess up for me?
Old Aug 18, 2003 | 10:07 AM
RCautoworks's Avatar
This should help
Old Aug 18, 2003 | 10:37 AM
Doctor CorteZ's Avatar
jesus.
clean up that rats nest , make sure the MAP is on the TB post and ditch the rest , plug what needs it and be done with it.
Old Aug 18, 2003 | 11:11 AM
rsbad454's Avatar
Default Re: crx hf to b16a1 vacuume problems?? please help pics inside (Doctor CorteZ)
you will probably do away with a lot of those lines.........
Old Aug 18, 2003 | 11:22 AM
Default Re: crx hf to b16a1 vacuume problems?? please help pics inside (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">you will probably do away with a lot of those lines.........</TD></TR></TABLE>
see above post.
Old Aug 18, 2003 | 03:06 PM
crx1856's Avatar
according to the diagram, the fpr vacume line is susposed to go to the firewall. i've always heard it goes to the port in the back of the intake manifold. which is the corect way?
Old Aug 19, 2003 | 04:44 PM
crx1856's Avatar
i got rid of all the junk except for the map and the purge valve. car runs alot better now but when i start it cold, it revs to about 2k, drops to 1500, and raises up a tad. when it warms up it idles about 1k or a little less depending if the fan is on or not. is the cold start normal or is something still wrong?
ymibuyingmore
Jun 12, 2011 06:08 PM
crx1856
Aug 18, 2003 10:55 AM
crx1856
Aug 18, 2003 08:46 AM
crx1856
Aug 16, 2003 02:57 PM
