My damn antenna!!!!!!!!!!!!!
Old Aug 12, 2001 | 09:30 PM
94autotegLS's Avatar
New User
Default My damn antenna!!!!!!!!!!!!!
I have heard a couple of teg owners complain about this but whats wrong with my antenna!!! It makes a horrible noise when i turn on the cassetter player (soon to be explode cd player) and when i turn it off , anybody have a similiar situation.
This should have been the first question i asked when i first joined this site. Can Anybody offer any help or advice to end this embarassment ????
Old Aug 12, 2001 | 09:35 PM
GSRgrrl's Avatar
Default Re: My damn antenna!!!!!!!!!!!!! (94autotegLS)
Probably needs to be lubed.
Old Aug 12, 2001 | 09:36 PM
xsnrgsr
Guest
Posts: n/a
haha, you mean....brrrrrrr pop pop pop pop!!?? its the motor still trying to pull the antenna down and slipping on the teeth on the plastic cord inside your antenna. It must have slipped a few teeth and is now "uncalibrated".
That happened to me too, i got a new antenna from pepboys and it did it too! if you cant stand it, get a new acura one, stay away from the cheap autoshop replacements!
Old Aug 12, 2001 | 10:05 PM
Phat Corolla's Avatar
New User
Default Re: My damn antenna!!!!!!!!!!!!! (xsnrgsr)
Get rid of your antenna or make a switch to make it stay up or down. (I used the switch idea, cuz i hate my antenna up.)
Old Aug 12, 2001 | 10:12 PM
New User
Default Re: My damn antenna!!!!!!!!!!!!! (Phat GS-R)
What would be the best solution would i still get frequency without an atenna if i do go the acura route how much am i looking to pay i dont want to spend to much on this problem???
Old Aug 12, 2001 | 10:20 PM
New User
Well...you do still get signal with the antenna down, however its not that good. You could replace it with your everyday cheap antenna from an auto parts store, but it might not look or work as well. If you were to go to acura, it would cost you way too much. For example, I bought the little plastic pocket for under the stereo...it cost me 30 bucks...not the best deal ever. Good luck on finding a solution.
Old Aug 12, 2001 | 10:28 PM
New User
I need a solid solution!!!!! anymore ideas??
Old Aug 13, 2001 | 09:28 AM
Big Ed's Avatar
Swap it out for an S2000 antenna, here's more info: http://www.bseries.net/html/garage/s2kantenna.php
Old Aug 13, 2001 | 11:02 AM
DavidGSR's Avatar
Default Re: My damn antenna!!!!!!!!!!!!! (Big Ed)
Same problem here. I keep it lubed / cleaned with WD 40 every month or so. If it gets "uncalibrated" I just pull it out / push it in by hand to reset it, and then clean it again. I also put in a switch so I can stop it from doing it when it is a problem (when it gets cold).
Old Aug 13, 2001 | 11:25 AM
pete-o's Avatar
New User
Default Re: My damn antenna!!!!!!!!!!!!! (DavidGSR)
I recently had to replace my antenna. The part from my acura dealer cost $30 and it's really easy to install. I replaced mine because it had gotten broken, but before I replaced it was also starting to make some pretty bad noises. I don't have any of those noises anymore with the replacement antenna in. Spend the 30 bucks and install it yourself. It's a quick, easy, and cheap solution.
Old Aug 13, 2001 | 11:49 AM
ThaJazz's Avatar
Default Re: My damn antenna!!!!!!!!!!!!! (pete-o)
I replaced mine with a Zendar mini-racing antenna.
Old Aug 15, 2001 | 12:03 PM
samagon's Avatar
sorry, for shooting this one to the top again.. but is there another URL that discribes this, I can't seem to get to the URL at all..
or can you explain it?
thanks
vietintegboi
Sep 8, 2006 01:00 PM
1994typeR
Jan 11, 2005 08:31 AM
sonicblueteg2k
Feb 7, 2003 10:57 PM
digitalspice
Audio / Security / Video
Oct 10, 2001 03:30 PM
