Idle surging problem !!!
Old Aug 17, 2003 | 11:53 AM
baonest1's Avatar
Default Idle surging problem !!!
Car is untuned LS/VTEC 2.0 liter hondata s200, have tried fuel pressure adjustments and dist. timing to repair problem but neither fixed it. Have tried unplugging IAC, IAT etc... engine runs worse so I know that they are functioning properly... any suggestions...? Idle surges from 1000 rpm to 2200 rpm constantly any help appreciated. thanks
Old Aug 17, 2003 | 01:01 PM
baonest1's Avatar
anyone
Old Aug 17, 2003 | 03:58 PM
baonest1's Avatar
Default Re: (baonest)
maybe one reply before next friday?
Old Aug 17, 2003 | 04:23 PM
sweet's Avatar
i've had problems like that in the past. ended up being the TPS sensor even though i thought that would be the last thing possible. i checked the IACV, MAP, Vacuum connections etc. before swapping the TPS.
when i unplugged the IACV the idle would drop from 1200-2500 surge to about 1400-1500 surge so it wasn't as annoying to drive. but of course when i unplugged the IACV the CEL came on. but with everything plugged in there weren't any CEL's. that's the wierd thing. it was the TPS but never got a code for that. you may want to try that if you haven't yet.
Old Aug 17, 2003 | 05:29 PM
baonest1's Avatar
Default Re: (sweet)
we actually got it fixed... we disconnected the purge line from that charcoal canister and plugged it. runs perfect.. just dont know the long term effects of it.
Old Aug 17, 2003 | 05:51 PM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">we actually got it fixed... we disconnected the purge line from that charcoal canister and plugged it. runs perfect.. just dont know the long term effects of it. </TD></TR></TABLE>
ok, hope you got it fixed.
B17DA-SON
Feb 5, 2010 09:23 PM
mikeunreal2
Mar 29, 2006 09:27 PM
B18cHatch06
Dec 30, 2005 09:30 AM
EsCo_EsCo
Aug 21, 2005 09:21 PM
mafay2
Jul 13, 2005 11:52 AM
