best turbo manifold for crx?
What in your opion is the best manifold for a b16a and also fits a stock radiator,
im thinking of going wiht a t3/t4 turbo but i havent a clue what manifold i should be shopping for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">Fits with stock radiator, I'd go do some measuring if I were you. There is a lot less room than you think.</TD></TR></TABLE>
are you talking about the log manifold?
you honestly can't beat the price for a Lovefab manifold and the craftmanship...pretty much can do what you are looking for. go look for "tinker_128" under member search.
or do a search for "lovefab" in the forced induction section.
I have a log manifold and there wasn't a snowballs chance in hell of using the stock radiator. However if I was externally wastegated I could have designed it a little different and probably pulled off using the stock rad.
on my old setup i was running a b16 with a drag manifold, t3t4, tial 35mm wastegate, and a stock radiator. the only problem i had was that the top of the wastegate would hit my hood. so we plasma cut a peice off of the hood and had to shave down the top of the wastegate.
but i had no problems at all with the stock radiator fitting.
another one of my buddies has a b16 with a greddy kit with the internal wastegate and he is still using his stock radiator too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">I have a log manifold and there wasn't a snowballs chance in hell of using the stock radiator. However if I was externally wastegated I could have designed it a little different and probably pulled off using the stock rad.</TD></TR></TABLE>
dont u have hcp mounts? i have the old school hasport if that makes a difference
I used a F-Max and now an Inline Pro successfully. The Inline Pro is a BEAUTIFU:L piece. Buy it, You'll be happy. Just have to get a slimline fan or two.
Plenty of room for a stock radiator, as you can see. When the compressor is rotated for an air/air intercooler setup, it's even more room. We're even able to squeak a "reasonable" 3" downpipe in there with a JimFab bar setup.
trust me just get a 92-95 half radiator for like $100 and then get the lovefab mani that way if you ever want to get a bigger turbo like a 60-1 you wont ever have to worry about the radiator again.
red civic standard
11
Jun 29, 2007 04:03 PM
h22_crx
May 5, 2007 03:08 AM
19sec beast
Jun 13, 2005 05:31 AM
