Buying springs.
Old Aug 17, 2003 | 08:45 AM
The Destroyer's Avatar
Default Buying springs.
Well guys I did a search, barely anything came up. My goal isnt to lower the car much, its to get a stiffer ride. Now im buying itr struts, springs, and the itr srr lca. this will be for an eh2.
My 3 choices as of now.
Tein Tech S: Lowers the car, havnt found many spring rates though.
Comptech: Lowers the car 1/2 to 3/4, but still havent found spring rates.
Tanabe sustec GF210: The car is lowerd between 30-40mm, and spring rates are 20-30% over stock.
But on there websites I havnt found the actual spring rates, im pretty sure some of you have one of these springs. So if anyone could throw in there .02, good or bad. Would be appreciated.
Old Aug 17, 2003 | 09:22 AM
kkim's Avatar
Default Re: Buying springs. (MagillaGorilla)
http://php.indiana.edu/~bchang....html
Old Aug 17, 2003 | 09:56 AM
C-Westin ITR's Avatar
Might wanna check out Zeal suspension. its great.
Old Aug 17, 2003 | 10:36 AM
JoshRambo's Avatar
Don't forget about H&R springs. They will be better than the comptech ones.
Old Aug 17, 2003 | 01:11 PM
Default Re: Buying springs. (kkim)
Thank you kim for the rate table.
EDIT: The zeals are coil overs, I just need springs.
Is too stiff of a spring a bad thing? I dont care if the car feels ever little dimple in the road.
Modified by MagillaGorilla at 2:26 PM 8/17/2003
Old Aug 17, 2003 | 05:51 PM
Dr Pooface's Avatar
wont eibach make custom rates/sizes? Or hypercoil?
Old Aug 17, 2003 | 06:45 PM
blanktape's Avatar
Kg/mm supersports or Spoon Progressive are two good choices!!!
Old Aug 17, 2003 | 06:52 PM
oryanh's Avatar
Default Re: (blanktape)
I'm a Tein Stech (medium) man myself... I love'm.
Old Aug 17, 2003 | 07:09 PM
Michael Delaney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla &raquo;</TD></TR><TR><TD CLASS="quote">
This is why you spend the big bucks on a good set of shocks (cough* koni or bilstein not tokico or agx *cough).
The people feeling every dimple are the same ones who ride on stock shocks after they upgrade their springs .
Old Aug 17, 2003 | 07:17 PM
itralex's Avatar
Default Re: Buying springs. (Michael Delaney)
ok, can somebody help me out?
is it alright to run with S-techs and stock shocks?
i know with other springs you'll need shocks for sure but i haven't heard anything about the s-techs
Old Aug 18, 2003 | 06:07 AM
oryanh's Avatar
Default Re: Buying springs. (HypeR1004)
I've run on my S.Tech mediums for nearly 30k miles on stock shocks... comfy ride.
Old Aug 18, 2003 | 06:39 AM
typer_801's Avatar
Actually, the reason you feel every dimple on stock shocks is because the Koni and Bilsteins are softer than stock (at least in the rear). I don't know of any aftermarket off the shelf rear shocks except for the GAB's and Tokico Rallye rears that are stiffer than the OEM ITR rears. Both of those are reasonably challenging to get ahold of as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">
The people feeling every dimple are the same ones who ride on stock shocks after they upgrade their springs .</TD></TR></TABLE>
JDMswagSerf
Suspension & Brakes
17
Feb 21, 2016 05:48 PM
i-VTEC_do_you
Suspension & Brakes
Mar 13, 2011 05:31 AM
SpoolnG2
Suspension & Brakes
Apr 24, 2006 06:49 PM
Stag 2000
Honda S2000
12
Feb 20, 2003 07:41 PM
