SAFC on bolt on ls ?
Old Aug 17, 2003 | 07:19 AM
RacerXintegra2k's Avatar
Default SAFC on bolt on ls ?
i'm thinking about getting the apexi SAFC for my car. is it worth it . i have a 2000 ls with i/h/e what kinda of numbers would i get and would i even need it ? how much of a pain in the *** is it to get setup.
Old Aug 17, 2003 | 07:42 AM
ragejed's Avatar
Default Re: SAFC on bolt on ls ? (RacerXintegra2k)
He also thought about a high flow cat
Old Aug 17, 2003 | 10:56 AM
Yosshaa's Avatar
i put a SAFC in my car wit i/h/e/bores tb/ and skunk2 manifold... with fuel tuning i gained ten whp... so it was worth it for me
Old Aug 17, 2003 | 11:22 AM
TeamSTEALTH GSR's Avatar
Default Re: (ambition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">i put a SAFC in my car wit i/h/e/bores tb/ and skunk2 manifold... with fuel tuning i gained ten whp... so it was worth it for me</TD></TR></TABLE>
sounds about right...
with basic bolt ons(i/h/e) a safc with some dyno tuning would bump u up 7-10whp..
Old Aug 17, 2003 | 12:10 PM
StyleTEG's Avatar
Default Re: (TeamSTEALTH GSR)
Get a highflow cat or testpipe first.
With the afc, also look into cam gears and a FPR. Adjusting just the A/F is really only going to smooth out the powerband, where cam gears will let you tune some more power out of the stock cams.
Old Aug 17, 2003 | 12:20 PM
Default Re: (StyleTEG)
hmm really 7-10 whp wow that good with just i/h/e might have to pick one up .. has anyone mounted it undernieth the cd player .. there is a gap their i wish i could put it their i dont really wanna block my stock gauges.
Old Aug 17, 2003 | 12:25 PM
fivespeedintegra's Avatar
Default Re: (RacerXintegra2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXintegra2k &raquo;</TD></TR><TR><TD CLASS="quote">hmm really 7-10 whp wow that good with just i/h/e might have to pick one up .. has anyone mounted it undernieth the cd player .. there is a gap their i wish i could put it their i dont really wanna block my stock gauges.</TD></TR></TABLE>
i believe a lot of people have mounted it there before
Old Aug 17, 2003 | 01:01 PM
Default Re: (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">
i believe a lot of people have mounted it there before </TD></TR></TABLE>
i had it mounted there also, but no more.. now its in my glove box...
a cop can pop ur hood if he sees the afc..., its probable(sp?) cause to look under ur hood.
he sent me to a referee
Old Aug 17, 2003 | 01:30 PM
damn that sucks .. cops arent to strict in CT though. umm can somone tell me what the install of the safc involves ? and how did u guys get it to fit in that spot under the cd player ? any cutting or drilling ?
Old Aug 17, 2003 | 01:49 PM
well to install it, u would need some electric tape, cuter, some gador grips or what ever does clips are called..
i didnt cut anything to mount it.... i just sliped the apex bracket between the cup holder and ashtry....
http://hiline.netfirms.com/jan15439.jpg
edit..: link dont work...
try this one.. scroll down to my car, black teg
http://hiline.netfirms.com/gallery.htm
Old Aug 17, 2003 | 01:53 PM
umm cant see pic. since you have to go to a dyno do u think the guys running at the dyno would install it for you and then tune it ? without like to much money extra.
Old Aug 17, 2003 | 01:58 PM
a dyno tune ur looking at about 120$ an hour.. and it should take about less then 40 minutes to just tune the afc... ask them if they'll install it for u.
i had my friend(who had installed one on his car) help me out... take less then an hour to install.
p.s. i edit the link..
Old Aug 17, 2003 | 05:42 PM
ooh thats not the spoti was talkin about i was talkin about the spot direcly under the radio
Old Aug 18, 2003 | 11:37 AM
my spot works for me
Morasso
Dec 4, 2007 07:36 PM
Yosshaa
Jun 13, 2003 12:30 AM
DOHCon15s
May 13, 2003 08:52 AM
riceburnah
Apr 20, 2003 09:59 PM
B00ST2nR
Dec 5, 2002 01:17 PM
